6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
New owner question
Old 05-14-2009, 10:39 PM
madmax99's Avatar
madmax99
madmax99 is offline
New owner question
Hi guys, I just got done doing my first oil change and per the manual the engine should take 15 quarts of oil with a new filter (which i did put in) but I found after 14 1/2 quarts I am over "MAX" level. I noticed from the factory it was over as well from the day I brought it home. Is there a trick to getting all the oil out or has anyone else found that the 15 quarts end up putting it over the max line. Oh and I did run it to get the oil into the new filter.
Old 05-15-2009, 06:28 AM
senix's Avatar
senix
senix is online now
Received 1,418 Likes on 1,013 Posts
When you drained it, did you let it sit for at least 20 minutes before starting the oil change? That could be one issue, not letting the motor oil drain back into the pan.
Better method is to put 14 qtrs in, run it, then check to make sure the oil is in the operating range.
You can also check your oil using the short stick method. Pull the dipstick, wipe clean. Then insert up to the plastic handle then pull out and read it. Highest reading on the stick is the one to go by.
joejackF250
06-11-2014 11:17 AM
XinOK
12-26-2004 09:57 PM
Lnd Svyr
12-14-2004 05:35 PM
tfr542
2004 - 2008 F150
07-14-2004 12:48 PM
Quick Reply: New owner question
