which carter afb carb for 351m?
I have a 2bbl on it now. Will be switching to a 4bbl electric choke with egr. I was looking at the 1400 edelbrock, but which series would I need to find in a carter afb carb that is egr capable?
I have found the carters are a little less money, but they appear to be indenticle.
With EGR, it's not the carburetor that matters, it's the intake manifold that matters. You can use the same carburetor for an EGR and non-EGR setup. You just have to use an intake manifold with the exhaust crossover. The EGR valve mounts to a spacer plate which goes underneath the carburetor.
jnj4fords
08-16-2006 07:46 AM
bigwalt1
12-11-2003 06:48 PM
351, 351m, 3771, afb, carb, carburator, carburetor, carter, edelbrock, egr, modified, thecarburetorshop
