5.0 serpentine belt walking off crank pulley
Old 05-05-2009, 07:53 PM
73FOMO's Avatar
73FOMO
73FOMO is offline
'92 5.0 f150 with stock brackets with smog pump removed. I tried several different belt sizes and then tried a 88.2 at the recommendation of another post I found on this site. Problem is after cranking 5 or 6 revs and I look down at the crank pulley, it looks like the belt has moved over one groove and is walking toward the radiator. This 88.2 belt is extremely tight, and the tensioner is at almost a 90 degree angle. I had to fight to slip belt under tensioner and it only pushed belt down a little when released. Routing is over the alt., under the tensioner, over the a/c comp., around the ps pump, the back side over the top of the water pump, around the crank and back to alt. The alignment of the pulleys looks pretty good. I am pretty sure I bottomed out the ps pump pulley when I reinstalled pulley. Any ideas? Belt too tight?
Old 05-05-2009, 11:24 PM
johnboy427's Avatar
johnboy427
johnboy427 is offline
Take the belt off and see if there is any slop in the water pump, it might not be running true to the crank making it walk of the crank pulley.
-Johnboy
Old 05-06-2009, 01:45 AM
JJ98's Avatar
JJ98
JJ98 is offline
also check to see if everything is in line did u change somthing water pump or anthing before this started to happen
Old 05-06-2009, 06:34 AM
73FOMO's Avatar
73FOMO
73FOMO is offline
I am going to post a pic of the PS pump showing the distance. I had the pulley off of it, and I thought I had it bottomed out, but I am thinking the pulley was closer to the mount. I can see where the belt should ride by the wear markings on the waterpump pulley and since the belt goes directly from ps pump to water pump the only thing it could be is the ps pump pulley is not bottomed out. I put a straight edge across the ps pump and crank and the ps pump pulley is still about 1/2 to 3/4 further out (toward the front), which would make the belt align itself on the waterpump, thus walking the belt forward 1 groove on the crank. Am I thinking right? I will post a pic shortly.
Old 05-06-2009, 08:45 AM
73FOMO's Avatar
73FOMO
73FOMO is offline
Here are the pics....
Is it me...or does it look like that PS pulley needs to go on more? Looking at this pic now...looks like the belt is at an angle going down to the pump. If anyone has a '92 - 96 f150 with these brackets I would appreciate a pic or a meaurement from the pulley to the bracket.
Do you think the 88.2 belt will be ok as far as tension (due to the tensioner only moving about 1/2" when released)?
Old 05-07-2009, 01:26 AM
Beanscoot's Avatar
Beanscoot
Beanscoot is offline
That belt looks really crooked and it sounds like it's much too tight. Pulleys don't usually change their location, but carefully check over all your accessories to determine which one is out of plane with the crank pulley.
Old 03-17-2014, 07:28 PM
coop589's Avatar
coop589
coop589 is offline
Hi,
Looking through old posts to look and learn how others solved this issue. Did you ever resolve this problem. My Dad's 1990 E-250 5.0L is doing the same thing at the crankshaft. Keeps chewing up the outer edge of the belt. Not sure if it may be the tensioner, or idle pulleys or both.
-Glenn
Old 03-19-2014, 06:08 PM
jimbbski's Avatar
jimbbski
jimbbski is offline
First you need to confirm that all of the pulleys are all in alignment. Until you do then nothing else you do will help.
Spktyr
24
06-09-2019 07:32 PM
jdemaris
15
11-05-2018 07:35 PM
94150
15
01-25-2017 03:41 PM
Fordication
11-17-2016 12:13 PM
86stepsideF150
08-27-2016 10:39 PM
Quick Reply: 5.0 serpentine belt walking off crank pulley
