any easy way
Old 05-02-2009, 07:57 PM
Eddiestruck's Avatar
Eddiestruck
Eddiestruck is offline
any easy way
IS there a easy way to tell the difference from a 429/460 to a 370
It's a 1985 F-350 I think stock was a 460 but the previous owner replaced with an engine from a camper
<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- edit note --><!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old 05-02-2009, 08:26 PM
4DTech's Avatar
4DTech
4DTech is offline
The easiest way without guessing which could be a little pain in the butt.. Pull the upper and lower intakes off and look at the valley The engine size should be cast into the block..... It sucks but it's better than guessing... Other than that figuring out what types of pulley configurations the engines had.. That could be a pain.... Good luck..
Old 05-02-2009, 11:02 PM
The "Mad Porter"'s Avatar
The "Mad Porter"
The "Mad Porter" is offline
Smile
The 370 and 429 HP engines were only put in heavy trucks. Not in an F-350 or E-350 van / RV chassis.
The HD engines have a cast iron front cover and center dump exhaust manifolds. They actually look very different from the truck and passenger car bbf's.
Old 05-02-2009, 11:50 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
to tell a 370 from a 429 on the HD engines look at the casting number above the starter, a 429 will be D9TE-AB (same as a light truck 460) the 370 will be D9TE-BB. Scott already brought up the diff between the 460 and the HD motors being the timing cover as an easy give away.
Old 05-03-2009, 08:29 AM
Eddiestruck
thanks yall
looks like these give me something to start with will go out and crawl the engine compartment after church today
Old 05-03-2009, 09:12 AM
Eddiestruck
as far as pulley config goes i know the previous owner messed that up cause there is no pully for the ac to hook up on.
I will be spending much time in the ford graveyards over the next few weeks
Old 05-03-2009, 10:22 AM
C-Leigh Racing's Avatar
C-Leigh Racing
C-Leigh Racing is offline
Well, Monsterbaby is alive, I was about to think you had done skipped town on us.
Nex time you think your going to be gone awhile, let us know so we wont worrie & maybe thinking some cheby guy done kidnapped you or something.
Neil
Old 05-03-2009, 10:39 AM
monsterbaby
I am around, jsut get burned out and/or busy sometimes and take a break is all.
Old 05-05-2009, 04:18 AM
Eddiestruck
mine has a rear dump exhaust my only flashlight died before i could read the numbers above the starter will post more later
sddesigns
New Jersey Chapter
04-20-2010 06:58 PM
sddesigns
New Jersey Chapter
04-14-2010 01:55 PM
THE BLUE HEAP
12-25-2009 08:18 AM
428HIGHBOY
15
02-17-2009 07:02 PM
Quick Reply: any easy way
