Want to level my 99 F-250. Do I need the early or late model 99 leveling kit?
I want to install a leveling kit on my 99 F-250 4x4. According to the info on the inside of the drivers door, my truck was built in 03/99. Does anyone know if I need to order the early or late model 99 leveling kit? Also does anyone have a recommendation on what brand to get?
Thanks
B.
Thanks
B.
The following users liked this post:
If your truck was built on 3/22/99' or later its a late model 99'.I have a Tuff Country 2 1/2" leveling kit on mine and I really like it.It rides a little rougher but not too bad.I think when I bought mine [2003']the kit was the same for either 99' model.They have different kits for gas or diesel.If I remember right the only difference was the bolt that hooks the track bar onto the drop bracket was different.The kit came with both bolts so it would work on either one.One good thing about the Tuff Country kit is the drop bracket has a slotted hole for track bar so you can get the axle centered without the use of an adjustable track bar.
I just installed a Procomp 2 1/2" kit on my 04 last weekend. I'm really impressed with the ride improvement in the leaf springs. It rides softer but with more control. The weekend I've started installing an add a leaf kit in the rear to bring up the back a bit. Both kits are from Procomp and came with everything and some decent instructions.
There is a difference. Mine was built 12/98. I bought the Icon mini pack and the U-bolts were wrong. Mine has different lengths between the inside and outside. The kit came with four that were all the same length. I just had a spring shop make me four new ones. It was only about $40 and they made them while I waited.
usmcBTC- don't despair just yet. You may be able to just get the proper U-bolts instead of having to swap the whole kit.
HOCK
04-02-2009 09:56 AM
