overloads
overloads
heya
When i put my 2000# camper on my truck, the overloads are not touching, about 2 inches away (it varies). I don't see this as doing any good, possibly because i have timbrens. I'm considering building some blocks to go on the stops, taking out the factory rubber piece. My truck has been lifted about 2.5" (matching an F350).
Thanks for suggestions!
Guy
Guy
You could try to tighten the timbrens down, but they're acting as your overload. Supersprings makes a bump stop (super sway stops) that is supposed to do what you're talking about. I've also seen a picture of someone removing the factory rubber stopper, bolting a 2" square tubing there and attaching the oem rubber to the bottom of the tubing to take up the gap.
Your Timbrens are working as your overloads (just as they are supposed to).
If you didn't have the Timbrens then the rear of your truck would probably be squatting down onto the factory overloads. Are you have any problems with it the way it is now because it sounds like it's working normal to me.
Sounds like you don't need them but the air bags are a great product if you want to have them in case you need them.
You can hook them up to inflate together so your load bearing is equal, or, you can make them independent and use them to compensate for an uneven load.
Just a thought, and, another option for a mod on your truck.
thanks gents! I had bags for my F150. they mount differently and are smaller. some guy's on RV.NET are having trouble with leaks after 3-5 years with their bags, so i'm glad to have the overloads. Timbrens sure help a lot, but i may as well be using the overloads during sway too. there are some bumpers to put there, and some guy's have used composite decking or aluminum. I'm pretty close, 2" on 3, have contact on one end of one leaf. I think i'll even them out with a slight block.
My main goal is just as you say David, I'm hoping this will help some of the sway, and save me the $250 on getting a rear stabilizer. Need new shocks too. And maybe a second job... (Garrett 38R, DPtuner, Guages, Tires...)
The "lift" is just like it was a 350, the big blocks the same size that are in the F350. the overloads look like they belong in a one-ton too. I think i'm just farther from the overloads because of the lift. No worries. just wanted to have them engage as i "sway" to form as anti-sway. thanks guru's!
http://www.rv.net/forum/index.cfm/fu...1.cfm#22686404
RV.Net Open Roads Forum: Photo Thread - Post a Photo of Your Truck Camper Here
'll have to check the gap next time i have the camper off. right now it's on (just getting it all ready for the camper now).
I see youre in corvallis, i'm down here in springfield!
i really like the timbrens, got them cheap on ebay used. they really made a big difference, and they are passive, not mechanical, meaning hardly a chance of failure like an air leak for peace of mind. Empty, there is some space between the stop and the rubber. They're real easy to mount up, and those factory ones are never gonna connect unless you do like that 1/2 ton chevy did. if you didn't see it, here it is:
http://www.arboristsite.com/showthread.php?t=96785
scroll down a bit and you'll see it.
Guy
Guy
I have the timbrens on my new '09 Chassis cab. I also have the 1" spacer that came with the timbrens installed. Timbrens are about 1/2" away from bump perch when unloaded.
My suspension behaves just as you are describing. The factory overloads never touch the overload stops. Loaded truck rides on main leaf pack and timbrens.
Does yours have any spacers. I would do something like you and others mentioned about putting in a spacer for the overload stops. I won't take out my timbren spacers because then the timbrens would make contact later. The truck would engage the factory overloads but it will sag more.
