540 CCA battery?
Old 04-20-2009, 08:12 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
540 CCA battery?
I posted in another thread about how the battery seemed way smaller in 09. I serviced one again today and right on top it says 540 CCA. That seems a little small to me. I think every 08 and older I've seen has 800+. Is there an option for something bigger?
Old 04-20-2009, 09:14 PM
Bsimmer3000's Avatar
Bsimmer3000
Bsimmer3000 is offline
Doe's your truck have trouble starting? Reason being is we had some stupidly cold days here and it had no problem at all. Could be another issue and not your batt.
Old 04-20-2009, 09:33 PM
brown 4x4's Avatar
brown 4x4
It's not had any problems starting that I know of (it's not my truck). I was just curious why Ford decided to downsize.
Old 04-20-2009, 10:59 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
did it have the 4.6 2v in it?
that motor doesn't need alot CCA...it is the Mustang motor after all
Old 04-20-2009, 11:41 PM
broncobran68's Avatar
broncobran68
broncobran68 is offline
The 5.4s have the 540cca too. Or at least mine does.
Old 04-21-2009, 01:35 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
wow
that just seems so...inadequate. Wonder what the reasoning is behind that one?
Old 04-21-2009, 07:26 AM
Bsimmer3000
I dont understand why it's ment to be larger? I could understand if the trucks had trouble starting in cold climates but 500+CCA shouldnt have any problem starting any 5.4 in 99.9% of climates.
Old 04-21-2009, 07:52 AM
ChargersFanInCO's Avatar
ChargersFanInCO
ChargersFanInCO is offline
my first 08 and my second one BOTH came with the 540cca. My first one died with no warning, and got replaced with the biggest one that would fit in the box. My second 08 got the battery replaced the first Saturday I had her. That 540 isn't enough for a well equipped truck.
Old 04-21-2009, 10:58 AM
04XLTRUNNER's Avatar
04XLTRUNNER
04XLTRUNNER is offline
i took that battery out and put the optima red top in out of my 05 that got wrecked.
Old 04-21-2009, 11:14 AM
v_tach's Avatar
v_tach
v_tach is offline
Why would you replace a perfectly good battery? Why not use it for it's useful life then replace it with your choice?
Old 04-21-2009, 11:22 AM
04XLTRUNNER
personal preference. just knowing that you have the power to start/run whatever you need in your truck without straining the alternator and battery.
Old 04-21-2009, 11:29 AM
Bsimmer3000
So is it going to be better for my engine if i put a bigger batt in?
Old 04-21-2009, 11:33 AM
04XLTRUNNER
well it wont hurt it. it really just depend on what your planning to do, running aux lights, winches, radio system, etc... stuff like that, then yeah i would go with a higher output battery. for stock, it would be fine.
Old 04-21-2009, 02:01 PM
v_tach's Avatar
v_tach
v_tach is offline
No. If your battery is in good operating condition, there is no reason to replace it. High duty conditions may shorten the life expectancy of the battery but replacing it prematurely offers no benefit other than lightening your wallet. Extreme cold, running lots of off-road lights frequently, or running high power audio amplifiers are some of the more common high duty conditions that come to mind.
Old 04-21-2009, 02:06 PM
Bsimmer3000
ohhhh good good. Would rather spend the money somewhere else.
Quick Reply: 540 CCA battery?
