Help with 1998 f-150 , will not charge.
Old 04-19-2009, 08:33 PM
Scott1957's Avatar
Scott1957
Scott1957 is offline
Exclamation Help with 1998 f-150 , will not charge.
i have a 1998 ford f150 truck, it will not charge the battery alt. is rebuilt had it checked twice battery is good 12.50 oms. Any ideas?
Old 04-19-2009, 09:44 PM
Ultramagdan's Avatar
Ultramagdan
Ultramagdan is offline
Nice to have you here!
If the alternator checks out OK and the battery is strong are you sure you don't have a short somewhere? When the truck is running, have you checked the alt to make sure it's charging the battery? Voltage regulator?
Old 04-20-2009, 12:52 PM
GammaDriver's Avatar
GammaDriver
GammaDriver is offline
Alternator while running should be higher than 12 volts with most vehicles. 13, or more, would be more like it. Check for the output of the alternator while running (even a bit off idle) and see if you need another rebuilt Alt.
Old 04-20-2009, 01:24 PM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
When the ignition is off, 12 volts at the battery is normal. When the ignition is on but the engine is not running, battery voltage should be 11 - 12 volts. With the engine running, voltage at the battery should be 13.5 - 15.0 volts.
Old 04-20-2009, 01:59 PM
Club Wagon's Avatar
Club Wagon
Club Wagon is offline
No idea where you get "oms"?
KRM02 has got the right idea. My '98 has sat for weeks & the pretty fresh battery still read 12.16 volts. When the key is switched on that dropped to 11.80 volts. Quite obviously charging, after sitting so long & on high idle, it read 14.36 volts.
IMO if you "have a short somewhere" you usually find out about it pretty quickly, especially in the large wires between alternator & battery. Shorts will ultimately pop a fuse/fusible link or smoke the wire until it burns out. More likely is a bad terminal or connection, that produces high resistance. This can fool a voltage regulator, acting like a fully charged battery.
Old 04-20-2009, 02:29 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
As club wagon mentioned it might be a blown fuse.
That was the prob on my Explorer when it was'nt charging. Replaced the fuse & problem solved.
Strangely enough the fuse is listed as "Generator/voltage regulator" on my 97 Explorer. Go figure. Tradition I guess.
Old 04-20-2009, 02:33 PM
KingRanchMan02
Nope, Ford classifies the device as a Generator these days.
FLHermit
08-08-2016 09:04 PM
Archuriel
10-01-2013 05:30 AM
O-Dog
12-17-2011 07:07 AM
WiNgRg
1997-2006 Expedition & Navigator
03-28-2010 11:48 AM
Lavern
1997 - 2003 F150
02-15-2010 03:40 PM
Quick Reply: Help with 1998 f-150 , will not charge.
