4wd switch not working ...how do i bypass
Old 04-15-2009, 09:51 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
have you gone and tapped that motor yet? take ya 5 seconds, and I can guarantee you 99% of the time, this is the problem
and don't be afraid to give it a good solid whack
and no, there are several distinctly different processes that the PCM and the t-case must communicate to each other during the shifting process.
any failure during that process, and no 4x4
Old 04-15-2009, 10:41 PM
calimove's Avatar
calimove
calimove is offline
i did give it a few wacks and no dif...
Old 04-15-2009, 11:37 PM
Matt983's Avatar
Matt983
Matt983 is offline
Then test with a multi-meter and see if its getting any juice to turn on. that lil motor is the bane of 4x4 problems with these trucks. It no worky your 4x4 no worky lol
Old 04-16-2009, 06:58 AM
xjcamaro89's Avatar
xjcamaro89
xjcamaro89 is offline
You need to check connections with a multi-meter before rewiring. If the solenoid motor is shot, to the point that a hammer doesnt work. It wont matter how many wires you re-run to the motor. You need to eliminate the motor as the problem before you go any further. Check the wires for the motor, at the motor to see if they are ok. Then move on from there.
Old 04-16-2009, 07:38 AM
jnick28's Avatar
jnick28
jnick28 is offline
I am new to this site so bear with me. I am having the same problem. I heard the grinding noise from the front left and now the 4x4 is not working. I changed the IWE solenoid and still nothing. The 4x4 lights do not come on and the 4x4 is not working.
Old 04-16-2009, 07:54 AM
xjcamaro89's Avatar
xjcamaro89
jnick, if you hear a grinding noise up front and your 4x4 isnt engageing, i think you might have a vacuum leak somewhere in the IWE system.
Read This:
https://www.ford-trucks.com/forums/8...ml#post7322441
Old 04-16-2009, 08:09 AM
jnick28's Avatar
jnick28
jnick28 is offline
Read This:
I will check the lines when i get home tonight. I did notice when i changed the solenoid that when i disconnected the lines there wa a bleed down of air pressure.
Old 04-16-2009, 08:12 AM
jnick28's Avatar
jnick28
jnick28 is offline
Nice article. I will check the lines. I did notice a sugnificant air bleed off when i disconnected the solenoind. Would that be an indication of anything? I really appreciate your help. Thanks.
Old 04-16-2009, 08:17 AM
xjcamaro89's Avatar
xjcamaro89
Well it depends what the conditions were when you disconnected the solenoid.
Sorry to hijack this thread.
Jnick-could you start a new thread for this problem if needed, thanks!
Old 04-16-2009, 08:19 AM
jnick28's Avatar
jnick28
jnick28 is offline
Sorry about the hijacking of the thread also. I'll try to set up a new thread. But while i have ya the truck had been turned off for about 10 minutes when i disconnected the lines.
Old 04-16-2009, 08:40 AM
xjcamaro89's Avatar
xjcamaro89
Well i think that would be normal because of the series of check valves and the vacuum box. But im not 100% on that. It could hold vacuum in the supply line and box from the first check valve to the solenoid. And the release you heard might have been that.
Old 03-29-2019, 01:38 PM
buttonbuck2017's Avatar
buttonbuck2017
buttonbuck2017 is offline
Transfer
Originally Posted by bridge
I might be wrong, but I'm fairly sure he'd still get the light on the dash if it was IWE Solenoid. You also tend to get some other symptoms with bad IWE's or IWE Solenoid...usually a grinding noise.
Would this take the tranny outta gear in a 5 speed and sound like it's spinning freely?
  #28
Old 03-29-2019, 08:32 PM
3Prcntr's Avatar
3Prcntr
3Prcntr is offline
I didn't get a light on the dash and it was my IWE. However, when trying to engage 4wd it would stick in either low or high whichever I went to first and not disengage, then the IWE sounded like a chainsaw.
Don't just bypass anything. You run the risk of screwing more things up or being stuck in 4wd hi or low. Figure out why and fix it properly.
I'm guessing at 15 days later, it was the motor and it got replaced.
  #29
Old 03-29-2019, 08:57 PM
buttonbuck2017
I have the same problem with not seeing the light. I'm also having the problem of it seeming like the transfer case is in neutral and I have to hit 4x4 button for it to kick back in. I have 94 ranger by the way
  #30
Old 11-25-2019, 04:23 PM
timc9999's Avatar
timc9999
timc9999 is offline
Not switching out of 4wd 2007 F150
Im having the problem of mine not switching back into 2wd, it is in 4wd, light says it is in 4wd but nothing happens when i turn the switch to 2wd or 4lo
rwm8082_2
08-08-2017 02:57 PM
FUJINAMI1293
01-12-2017 07:10 AM
ExPACamper
10-27-2016 07:46 AM
fredws
09-16-2016 09:49 AM
Vegas123
78
12-07-2015 01:37 PM
Quick Reply: 4wd switch not working ...how do i bypass
