2wd leveling Kit - Installed
Old 04-15-2009, 08:35 PM
F250_'s Avatar
F250_
F250_ is offline
That's where I got the $10 price from, Jim. For the length of these bolts, they won't fit even at an angle in the smaller $4.50 boxes, and the next size jumps to about $10 really quick.
  #32
Old 04-16-2009, 06:29 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
Ok I was just throwing it out there.
  #33
Old 04-16-2009, 09:58 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Eegads! I didn't realize those bolts were that freaking long.
Stewart
  #34
Old 05-02-2011, 06:37 AM
arusty1's Avatar
arusty1
arusty1 is offline
Old thread, I know, but this is the info I came up with on this topic;
I installed 2" aluminum spacers only to to find out that it can't be aligned without grinding the upper part ot the spindle,
and..
if that's done it still puts the upper ball-joint to the outside of it's range of motion.
Not to mention that the loss of castor is unrecoverable.
The correct way would be to use 2" drop brackets which nobody seems to make.
'03 250 2wd sc/sb
Any help would be appriciated.
...Rusty
  #35
Old 08-30-2011, 01:39 PM
StealthAssassin's Avatar
StealthAssassin
StealthAssassin is offline
The leveling kit for the 2wd does not work...
  #36
Old 08-30-2011, 01:41 PM
StealthAssassin
Ditto about the drop brackets! Wth does daystar sell this kit when it does not include drop brackets???
  #37
Old 08-30-2011, 03:09 PM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
I hate to disagree but the leveling kits do work, Many of us here (myself, grady, Frank, Joe) have them installed and aligned without any problems. On some trucks the spindle does have to have a little material ground off. If you feel "lucky" try the install without removing any material, the downside if you do have alignment issues you need to remove the spindle and do a little grinding. I had to remove about 1/16" inch off of mine (really quick job with a grinder).
Rusty, if your alignment guy cant get it aligned find another front end guy because it can be done.
Check out this thread:
https://www.ford-trucks.com/forums/1...kit-is-on.html
  #38
Old 08-30-2011, 03:36 PM
Stewart_H's Avatar
Stewart_H
What do you mean it doesn't work? Are you saying it doesn't lift the front-end at all, or are you saying the truck isn't perfectly level after installation?
If you're saying it isn't perfectly level, then yea, you're right. There is still a slight front-to-back rake. But I like that.
Stewart
  #39
Old 08-30-2011, 03:42 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by RedBoat
I hate to disagree but the leveling kits do work, Many of us here (myself, grady, Frank, Joe, Stewart)
https://www.ford-trucks.com/forums/9...ml#post8492932
Added a little to your quote.
Stewart
  #40
Old 08-30-2011, 05:49 PM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
Sorry I missed ya Bro!
I probably missed quite a few others: Parts Guy Ed, Big Joe, JoRge, Chris..........
  #41
Old 08-30-2011, 06:44 PM
gtnwood's Avatar
gtnwood
gtnwood is offline
I have the aluminum kit installed as well, no grinding required but did need to get a cam kit since the alignment was out of tolerance adjustability but it rides smooth as a you know what now and looks better to. Franko helped me immensely during my install cuz it was about to be yanked off till gettin with him.
  #42
Old 08-30-2011, 07:26 PM
StealthAssassin
Ok, how did you get the camber adjustment right? The steering knuckle hits/bottoms out the I beam before the wheel even gets plum by eye...
  #43
Old 08-30-2011, 07:28 PM
tojoski's Avatar
tojoski
tojoski is offline
Mine installed without any grinding, although it was pretty close..I had to get the adjustable cams to get it to align,
I'm still running the older hard plastic type, one of these days I'm gonna switch them out for the Aluminum ones.
  #44
StealthAssassin
I'm not real crazy about grinding the knuckle.
  #45
Old 08-30-2011, 07:43 PM
StealthAssassin
I meant the I beam
Quick Reply: 2wd leveling Kit - Installed
