Wiring problem...
Wiring problem...
Is there any chance someone could direct me to a diagram for wiring turn signals. They used to work but I have the feeling something got disconnected. I've uploaded some pictures for your viewing pleasure... by the way, I've taken the truck out a few times on the road now, it feels great!
I know they are just random pictures but maybe somebody could either direct me to a diagram or pick something out? Thanks!
Hey Max, I would trace the wires back from turn signals to be sure which connections to look at, also put a meter on those glass fuses to be sure one hasnt gone bad. On these old trucks sometimes if you have one turn bulb go out it can affect part or all of the circuit...
Get you meter out and start tracking, good luck
Ed
Ed
Here's the basic wiring diagram for the type of turn signal system you have. You have to determint if you have the five wire or seven wire system. With the five wire switch you need two sets of rear lights, one for turn signals, one for brakes. With the seven wire switch you only need one set of rear lights because the switch has an internal switch that opens the brake circuits, see the bottom animation:
In his picture, it appears that his flasher plug has 3 leads on it. The black wire should be going up to the switch, and the red wire with half the fuse holder should be coming from switched power to the flasher. The two white ones are not connected at all and this is certainly going to be a problem.
I made this diagram when I rewired my truck. It is for the "Everlasting" type switch, but will show you the hook ups in the 7 wire system with three wire flashers, and I think is the same as Bob's 900 series drawing. The colors I show coming out if the switch are the correct colors for that switch but you can see later on down the line I may have switched to a different color. I'm providing this for signal flow.
Here ya go:
If you have trouble reading it go to http://members.***.net/japeterson/49...g_Wiring.ppt#2 There are two like this, one shows all my extra toys and one is generic - you will see the difference!
Or if you like, just send me a PM with your real e-mail address and I'll send you the full size drawing in Power Point.
Good luck
Here ya go:
Good luck
