Hot drum brake - again!
'99 Ranger xlt 3.0 ltr. 4x2 105,000 mi.
Just installed rear brakes and spring kit. Left side only needed a self-adjuster kit. I cleaned everything up inside and put dabs of grease on the friction points. I also bled them both, then sailed through Pa. state inspection. The left rear drum is always very hot when I get home so that you can't hold your hand on it and the right is just warm. (I live at the bottom of a long hill). This happened a few years ago when I last replaced them. You can't feel it when braking, but I think the left remains on for a time after the brakes are released. Can't figure out why this would happen. Can that equalizer valve on the rear brake line go haywire? The bleeding went smoothly on both wheels.
coppertales
13
07-31-2015 09:38 AM
Biggone
10-12-2014 12:22 PM
Sycostang67
04-25-2013 10:11 PM
