Brake drum does not go on all the way.
We just did a ton of work on my friends 82 F-150. When we were replacing the rear brakes, we noticed that on one side, the drum did not completely cover the brake shoes by about .25". The old shoes had a ridge worn in them from this. Both drums look the same and have the same markings, although I neglected to measure the width of each one. This is a 9" rear axle with 11" drums. The only thing I can think of is maybe the bearing wasn't pressed onto the shaft as far as it should be causing the axle to stick out further. The drum is sitting flush on the axle, but just not covering the shoes.
Did you tighten up the ratcheting adjuster on the brake shoes before you slid the drum over them? You're supposed to tighten them enough to slide the drums on, then expand them all the way out with the drum and tire on to center the shoes. Then, retract them until they stop dragging (best way to do this, I've found, is to jack it up and spin the tire by hand) and they'll self adjust as you drive.
EDIT: Just had a "dumb moment" and didn't fully pay attention. I wonder what's causing your axle shaft to stick out like that? I don't think a bearing would cause that, but I also don't really know. Is the backing plate tight?
Jim and Austin
64
01-30-2016 01:43 AM
Broomfieldbum
09-13-2009 05:16 PM
nightskyisme
12-08-2004 06:56 PM
Tedster9
10-10-2002 11:31 PM
fever22
06-17-2002 08:30 PM
