View Poll Results: What is the rating of this swap?
Voters: 15. You may not vote on this poll
Engine Swap -- Whats the deal?
do you have the rest of that truck?
and are both trucks 4x2 or 4x4?
there are different vacuum and electrical stuff depending on the year, and the drivetrain
then you got exhaust to figure out...motor mounts
hope you have the original truck to source parts from...especially the PCM and the wiring harness for that 5.4. The PCM for your 4.6 won't work with the 5.4 PCM. and you'll have to tell the CAN-BUS OBD-II system in your truck to accept the 5.4 parameters
you are kind of in no-mans land. I haven't heard of anybody else doing this swap yet.
mechanically, it will pretty much all just bolt up....it's the electrical stuff that'll screw you IMO
you should probably drop into the motor section of FTE and ask around in there. We can get you some general info in here...but you need the expert info from Techs and those who have gone before.
Is there something wrong with the 4.6 in your 05? If not I wouldn't mess with it. To hard for the small power gains you would get. A lot of people don't give the 4.6 credit it is a great dependable motor that puts out respectable power especially in the 04+ where they went to a 3 valve heads. JMO maybe I am biased because I have one and couldn't afford the 5.4 when I bought my truck.
fixed my quote for better reading ease
