Why was this in my vacuum hubs?
I had one side that was "stuck". I would rotate the tires and move the drive shaft. I swapped sides and the sticking went with the hub.
I pulled out Guzzle's instructions and took it apart.
When I was wiggling the inner gear to get the hub apart, it blew apart.
This is the first locking hub that I have taken apart, so I was at a loss.
Since Guzzle's pictures didn't show this spring, I figured that it shouldn't be in there (such power that Guzzle wields over people ).
I think that the previous owner put it in there to make the hubs lock. I haven't tested them. (have sway bar bushings off and can't find someone to press out the old bushings.)
Am I right in not putting this back in.
Bob, I think Guzzle's procedure does mention and show that spring. Take a closer look. Also attached another link for auto hub service that does show the spring. Good luck.
2004 F250 ESOF Hub Service
It doesn't show the spring, so I didn't think about it being inside the nylon hub.
I will pull it back off and try it again. At least with the spring out, the axle doesn't turn.
Since I can't manually turn either side, I am watching Craig's list and FTE to find some others to rebuild.
Thank for the other pictures, they show the spring very well.
WMRiceman
05-20-2007 10:21 AM
