Friction modifier!!!!!!!!!
I used ROYAL PURPLE synthetic 75w - 140w and was told I didn't need modifier. well, I did need to use modifier because I also had the chatter after the oil change.
I added the modifier and after a couple hundred miles, the chatter went away.
What synthetic oil did you use ?
what does this chatter sound like, i have a growling noise coming from the front end online when the hubs are locked in and the truck is in 4wd. i did the front end over and since then i have hasd this problem, dont know what it sounded like before as i had to do the front end right when i bought the truck. i figured the growling was coming from the blue seals that you have to press on to the axles. i did add friction modifier though, i think 4 ounces.
Sounds like the wheel hub assembly to me.
You Royal Purple user might want to read this.
Besides I scored my RP gear oil off e-bay for $20 so I'm not going to cry over $20.
And that is right, you don't need a friction modifier in the front.
