I'm Looking for a 7.50 X 20 Tire!
Old 04-05-2009, 03:35 PM
F500Mike's Avatar
F500Mike
F500Mike is offline
Does anyone know where I can find good 7.50 X 20 tires? 10 ply bias is what I need. It is for my old 1956 F500 (5 tone).
Old 04-05-2009, 03:36 PM
Bdox's Avatar
Bdox
Bdox is offline
Do a search for "Dick Cepek" tires. They used to have a lot of specialized tires that larger companies don't bother with.
Old 04-05-2009, 04:35 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
Universal has them in 14 ply. Here's the link - Universal Vintage Tire . So does Lucas Tire. Their link - http://www.lucasclassictires.com/Bia...3302009www.htm . Coker lists it too but a lot more expensive.
Old 04-05-2009, 05:09 PM
F500Mike's Avatar
F500Mike
F500Mike is offline
Holy @#*@ ! These folks are proud of their tires!
Old 04-05-2009, 05:22 PM
truckdog62563
Interesting to me that you have tube type multi-part 20s on a 56. I thought 56 was the first year for tubeless 22.5s. If your rims are the kind known as Firestone RH-5°, also called "widow makers", you may have trouble finding a shop to mount new rubber on them. Here's pics of them.
Old 04-05-2009, 05:24 PM
CAMiniTruck's Avatar
CAMiniTruck
CAMiniTruck is offline
I just bought a set of 6 10-ply 7.50-20 tires/tubes/flaps, installed with house call, from SM Tire here in California. Tires are Akuret Cargo Hiways. I believe the tires were around $100 each (whole package was ~$1200).
Old 04-05-2009, 06:05 PM
F500Mike's Avatar
F500Mike
F500Mike is offline
"widow maker"... great...
Here's a couple of pictures. They are definitely 20's. Lug nuts are 1 1/2 (socket size) and 5 lug. If there is a way to convert these to something else (like 22.5's maybe) I'd consider that too.
Old 04-05-2009, 06:53 PM
CAMiniTruck
Not all two-piece rims are widow makers - just an FYI. Look at the rim. If you have a 1" ring on the outer edge (look at the front tires first), then you have normal two-piece rims that will truck shops will service. If the edge of the ring is solid, then you have widow makers.
5-on-8 is a pretty common lug pattern. You can find 'safe' two-piece rims at places like Acme Truck Parts (Acme Truck Parts and Equipment: Heavy Duty Trucks and Truck Parts.) and you can possibly find some 22.5" with that bolt pattern through them as well.
Old 04-05-2009, 07:16 PM
WALFORD'S 56's Avatar
WALFORD'S 56
WALFORD'S 56 is offline
I have 2 spare 20'' rims with tires from my 56. The original owner swapped the 22.5s-which I have also. I kept the 20s because they were in good condition.
I am in Ohio....I called this past fall and Orwell tire locally had 20''on the rack and for 99.00 each mounted.
I love the pics....look at my gallery and I have had 5-6 big 53s-56s.......and a international diesel in a 56f350.......project....in build mode......but runs......good luck/Bill
Old 04-05-2009, 07:23 PM
truckdog62563
If I'm seeing right, those look like "lock rings" and, like the man said, they are serviceable at any big truck tire shop. You'll want to check them all though to be sure. Look for the raised band on the inside (concave) side to know for sure.
Old 05-18-2011, 08:18 AM
erickrtoledo's Avatar
erickrtoledo
erickrtoledo is offline
need tires
Old 05-18-2011, 10:18 AM
truckdog62563
Universal Tire sells USA made STA tires in 7.50 x 20" size. Below is the link. Stu
Truck - Truck and Military
Old 03-04-2012, 06:59 PM
justmax's Avatar
justmax
justmax is offline
super transport tire
I have three super transport tires 7.50-20. 8 ply rating with load range D
Tread depth 15/32
overall diameter 32
rim width 6
section width 8.7
(dual) maximum inflation: 2140
(dual) maximum load: 60
Let me know if this is what you are looking for
willowbilly3
1947 and Older Ford Trucks
04-27-2017 04:01 AM
willowbilly3
04-26-2017 09:19 AM
Ford f-500
Montana Chapter
02-23-2017 08:24 PM
352Mike4ever
03-30-2012 06:20 PM
brownfoot
27
03-21-2011 10:01 PM
Quick Reply: I'm Looking for a 7.50 X 20 Tire!
