Pioneer avic install help!!
Radio 12v lt. green/purple + radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink/black or lt. green/yellow + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on dk. green/purple + radio harness
Notes: This is the subwoofer amplifier turn on lead. The subwoofer and amp are in the driver side rear corner of the cabin. The subwoofer speaker wires are brown/orange (+), and red/black (-) at the radio harness.
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
Power Antenna N/A
Description
Factory amplifier integration harness (Click on part for more details)
Product Specifications
* -Factory Amplifier Integration harness
* -2 RCA plugs to mate to aftermarket radio's pre-amp outputs
* -One 24-pin power plug and one 8-pin subwoofer plug
* -A 1.5K Ohm resistor can be used on the amp-remote wire to eliminate turn-on pop.
Allows installation of an aftermarket radio using the existing factory wiring and connectors. No cutting of factory wiring is needed.
hey, I installed one in a 02 Explorer sport and the folks at AVIC411.com were a lot of help both with the install and with any other questions you may have.
definitely check out AVIC411.com, lots of good info over there. Be careful, they are a little tough on new guys sometimes lol
PostRelease
2009 - 2014 F150
11-02-2009 01:51 PM
Pittsburgh-05HD
07-05-2007 11:43 AM
trojanman1
133
08-22-2006 09:53 PM
