How do i reset my 98 check engine light ?
First off, fix the problem that set the code. Some codes will clear themselves when you fix the problem. Second off, document all the freeze frame data of when the code was set. Some codes are not as simple as they first seem, and this data can become valuable in the event future problems occur, or if the problem comes back. The best way to clear the code is with a code reader. Many auto parts stores can do it for you. Myself, I would get my own OBD-II reader and do it myself. Having the reader will come in handy. You can do it by disconnecting the battery, but that clears the memory of other things too.
If you use a code reader to clear codes, the light will go off and the history is gone. If you do the fuse thing or battery cable, the light goes out, bit the code stays in history. If the light goes off because the problem resolves itelf after so many drive cycles, it will stay in history also. I have tried it and that is how it worked. The CEL will come back on regardless of how you got it to go out if the problem still exists.
Removing the power resets KAM (Keep Alive Memory) which clears ALL accumulated data and stored parameters. Everything is is reset back to factory defaults and all the stored codes locations are zeroed out.
When our sons 2000 Sunfire had a plugged cat, the CEL was on. The battery was off for a week as I waited for parts. When I hooked it back up the CEL was off . I plugged in my scanner and pulled out at least 5 old codes, one of which was a cat code. Perhaps I should not have posted what I did on a Ford site since Pontiac may be different. Thanks for your input though on my mistake.
gthbryce
05-26-2009 03:54 PM
riyo2008
08-04-2008 11:43 PM
