have a 2007 F150. It has a button where I can eliminate the overdrive.
I use it towing to eliminate the constant searching.
Does the 2014 have a similar feature?
And, what is Tow Mode?
Thanks
It controls the shifts while towing in the 2003.5 - present Super Duties. Holds in in lower gears longer and drops from the high gears to lower faster...It is in the same spot as your overdrive button is. Actually called "TOW/HAUL" mode.
