Overdrive light blinking
Old 03-28-2009, 02:41 PM
rtpalin's Avatar
rtpalin
rtpalin is offline
I was out driving around in my 1998 F150 with a E4OD tranny and suddenly it started to shift very hard from 1 to 2 and 2 to 3. The OD light is blinking now. The torque converter lockup is still smooth along with OD. I am taking it in Monday AM. Any ideas what could the problem.
Rick
Old 03-29-2009, 07:49 AM
leforrest's Avatar
leforrest
leforrest is offline
I just replaced the ABS/Speed sensor in the rearend and mine doesn't seem to have any issues anymore.
Mine was a hard shift as well. Downshift to 1st was sometimes tough too.
I haven't had any problems since....knock on wood.
Go to an autozone and had codes scanned for free would be my first step.
Old 03-29-2009, 01:04 PM
Bobby82490's Avatar
Bobby82490
Bobby82490 is offline
Autozone cannot read transmission codes, you need a special code reader to read trans codes.
Old 03-29-2009, 01:17 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Not exactly. You don't need a "special" reader, you may just need a better one.
The ones that many AZ stores use are simple readers that only support generic codes. To be able to ensure that all codes are pulled (including transmission-related ones), the reader MUST support "manufacturer's specific" codes.
Check the features of the reader to see what it is capable of.
Steve
Old 03-29-2009, 01:34 PM
rtpalin's Avatar
rtpalin
rtpalin is offline
Hopefully the transmission shop will be able to diagnose the problem. While driving the truck to the shop today the tranny was shifting fine and the light is not blinking anymore. I had the transmission fluid changed last summer. I checked it in January because it felt like it slipped slightly when starting and it was down by 2.5 litres. Since then the level has not changed. I presume the was not enough fluid put in last summer. I hope that low fluid level did not cause the problem.
Rick
Old 03-29-2009, 04:01 PM
commandersander's Avatar
commandersander
commandersander is offline
You are having one of three possible issues....
OSS
TSS
VSS
These three sensors report along the same line to the ecm at various levels of impedance referencing ground.
SCT Programmers read these codes....They come up as PO-----
By John Patton
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/ Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/ Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/ Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear I Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stock On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stock Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
thr57
1997 - 2003 F150
07-17-2017 09:30 PM
Tmurphy38
1997-2006 Expedition & Navigator
11-13-2016 08:35 PM
bcaughhorn
11-13-2015 09:17 PM
Chris.Brame
1997 - 2003 F150
05-20-2011 09:04 AM
exlmtd
07-07-2003 04:02 PM
Quick Reply: Overdrive light blinking
