How to get a motorcycle into the bed?
on
If I were you I would go to Douglas Ga and pick up a trailer. It is a much more stable (lower center of gravity) way to bring your bike along.
Cargo Trailers, Enclosed Trailers & Utility Trailers for Sale - The Trailer Showroom
You can order it in the right color, with a ramp door. I would highly recommend the 24" tread plate aluminum option to protect the front and sides from rock chips. Also the v-nose option is nice for loading a bike (and fuel mileage).
The trailer idea is really best.
1. The Alcan highway is very rough in places you are about to learn what a "frost heave" is. I would not want my bike in the bed. It raises the center of gravity, there are some long curvey stretches and you will wish the bike was not back there.
2. You can load alot of other stuff in with your bike and lock the trailer. less worry about someone taking your bike, helmet, other stuff in the bed of your truck. The Alcan highway traverses through Northern British Columbia and the Yukon territory; beautiful country to be sure.....but also inhabited by a very depressed native population. Secure your belongings.
Buy a milepost book. It is the best reference you can buy for the trip. Better by far than any map and even better than a GPS.
Also, yes, secure your belongings! The silly bas**rds stole they hub off my front end while I was sleeping in the truck! They will take anything not tied down, and that's not even a sure bet!
Good luck on your trip!
i have a set of three 12' folding ramps. the center one is wider than the two outside ones. nice and long so they are not steep. you can put a riding lawn mower up without hitting the deck. my harley is 3-3/4" 's off the ground.transporting all three plus the bike can be a challenge. i was thinking about getting one of those half removable ladder racks that mount to one side of the bed and carrying them there. i'll walk out to the shed in a little bit and get the info off the ramps.
Thanks for the ideas everyone. I am sort of leaning towards two smaller ramps like such for a 4 wheeler. One to walk up while holding the bike upright.
I drove to Alaska last year in June with a friend and we tent camped the trip. We didn't have any problems but all of your junk was locked in the SUV which probably deterred people. You do raise a good point though, I should probably run a chain and lock through my ramps and maybe the rear wheel of the bike.
Well the bike was wrecked the other day but with any luck I can get it back from the insurance company by early next week.
I am really leaning towards something like this.
SMC-600 Sport Bike Hauler
I don't mind the large ramps, but putting them in the bed with my other belongings isn't going to fit. At least with this method, I can still use my entire bed while also easily and safely loading and unloading the bike.
I am a bit nervous about it but I don't have a reason to avoid it. For a long road trip I would probably hang my license plate on the outside of the bike so that I don't get pulled over for that.
Costco sells ramps in a set of two.
I'd go with two, one to walk up, the other for the bike. I'm a smaller guy, and have only done it single ramp once. It's not impossible, but the possibilities of an accident is very high. No stable footing to push off, push forward, or push away. (and I've seen others use a milk crate/bucket to get up on, bad idea.)
When you do find a suitable ramp, park with the rear tires of the truck against a curb, the other side on an incline (such as a driveway) so that the angle is less. Also, if the bike runs, you can stand to the side of it and guide it up easily in first gear at idle.
As for storing the ramp, I've seen a few use a hitch bike rack type deal to hold two ramps while other belongings hug the bike for the trip. I'm sure you could also make your own with proper tubing, that would be superior, but it's all a matter of time, tools, and materials, or money.
The cheapest way I found is to go to Home Depot and ask someone for ramp ends, they are on a top shelf somewhere that you'll never find. I payed like $10 or $20 bucks for them, then buy two treated 2x12x12' the caps bolt on each end. (two cap sets per box)
One end is the foot for the ground, and the other has a lip for your tail gate. they also come with pins to keep the ramp on your tailgate. (you have to drill two small holes)
Its alot cheaper than buying a set of ramps. I usually back into a shallow ditch to load/unload my Harley, and use the second ramp to walk up while holding the bike if need be.
If you use thicker wood, the aluminum end caps wont fit over the ends, they are desighned for 2x's, I used pressure treated, havent had a problem with my 800lb bike, other than being a little slippery.
Good luck. I had one break on me when I did a running start with my sportster and wound up ramming the bike right into the back of my brothers van. We had one break while we were putting a big lawn mower in a truck at work. So I am sure you can see where I don't trust any wood ramps. And I have seen them flex quit a bit with 600 pound bikes going up them so be cool with the wood.
#28
Its just a cheap idea if your only gonna use it from time to time. If your constantly loading/unloading your bike from the truck, i would recomend a better quality ramp.
#29
on
Put a backbone under your planks and you won't have the flex/snap problem.
I have driven a 91 F250 Diesel up my ramps, each ramp is made from two 10' Clear Green 2x12's, One is a little shorter to lesson the end edge on the ground, they are screwed and glued to each other with 2 Clear Green 2x4's screwed and glued to each other, screwed and glued on edge to the underside of the ramps as a backbone.
Put the backbone on one plank before gluing/screwing the two planks together.
We built them to load the race car.
I trust them far more than ANY Purchased ramps I have owned or seen!
-Enjoy
fh : )_~
-Enjoy
fh : )_~
SocialDistortionFan
18
01-15-2021 09:22 PM
