With running problems like this that throw no codes, The first thing to do before swapping parts and wasting time is to double dose it with gas line dryer! 2 bottles
of heet and 2 of iso heet. Water has a higher surface tension and will block small openings and not allow the fuel to get by as it is supposed to. Since it is heavier then the fuel after it has sat most of it drains down until the next time the demand hit's the
level that draws enough water back to the injectors/filter. You need to use both the methanol and the isopropyl since they work in different ways. Dump it in on whatever is in the tank 1/2 1/4 and then run it until 1/8 tank and refill with fresh fuel, A bottle of the
methanol every other oil change is good PM!!!
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
91 ford probe lx mtx The mighty vulcan 3.0
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!
