Ranger 3.0 problems
Old Mar 15, 2009 | 07:57 PM
djmac's Avatar
djmac
Ranger 3.0 problems
My buddy has a 97 Ranger with a 3. 6 cyl and he cannot get it running right and the weird thing is that it is not throwing any codes. The first thing I wanted to ask is how to diagnose is the ECU. I am not so sure that it is not running on limp home. It starts idles well for a few minutes and the idle turns rough. On the road it acts like it is running lean meaning the more you put your foot in it the more it gasps, absolutley no power. He has checked for a intake leak, changed the TPS, 02 sensor, crank and cam sensors pulled and tested the injectors without positive results. The vacumn is fairly low at a steady 15lbs and the fuel pressure is at 37 lbs and there is no CAT.
Any educated guesses?
Old Apr 6, 2009 | 01:28 PM
blue beast's Avatar
blue beast
With running problems like this that throw no codes, The first thing to do before swapping parts and wasting time is to double dose it with gas line dryer! 2 bottles
of heet and 2 of iso heet. Water has a higher surface tension and will block small openings and not allow the fuel to get by as it is supposed to. Since it is heavier then the fuel after it has sat most of it drains down until the next time the demand hit's the
level that draws enough water back to the injectors/filter. You need to use both the methanol and the isopropyl since they work in different ways. Dump it in on whatever is in the tank 1/2 1/4 and then run it until 1/8 tank and refill with fresh fuel, A bottle of the
methanol every other oil change is good PM!!!
Old Apr 8, 2009 | 08:23 AM
djmac's Avatar
djmac
Great idea! Thanks for the response I will forward this ASAP.
Old Apr 8, 2009 | 10:21 PM
djmac's Avatar
djmac
Well he tried the double dose and it is still running badly. He checked the fuel pressure and it is around 35 pds. He mentioned that the truck runs much better when he pinches the return line (partially) and gets the pressure up over 40lb. He has changed the regulator and the fuel pump and he claims he checked out the OEM fuel pressure and 35 is ok. Any other ideas?
Old Aug 10, 2010 | 09:02 PM
Monsta's Avatar
Monsta
Sit. Stay.
I gotta bring this to the top as my 94 is having the exact same issues.
Any help out there?
Old Oct 15, 2010 | 10:52 AM
gcdirtbiker18's Avatar
gcdirtbiker18
yeah my 91 is doing the same thing. i have no idea what it is...if i find out ill be sure to let you guys know
Old Oct 20, 2010 | 08:38 AM
tomw's Avatar
tomw
After checking the fuel pressure, I would try disconnecting the MAF. Run it around the block with the MAF disconnected, and if the performance comes back, you need to clean the 'heated wires' in the MAF. Do NOT leave the MAF disconnected for longer than a test drive.
If your vintage does not have a MAF, then check the MAP sensor. Make sure that you don't have vacuum leaks. Some have found leaks at the brake booster or the hoses on the vacuum 'tree' on the firewall. The MAF won't know about the extra air, while the MAP will note the vacuum is not as high, and will add some more fuel to the mix.
tom
RedTaurus94
1983 - 2012 Ranger & B-Series
Mar 11, 2016 04:37 AM
vintagequest
Jan 20, 2016 05:02 AM
gtrippleb
2009 - 2014 F150
23
Aug 1, 2010 09:17 PM
Visseroth
15
Dec 27, 2009 11:13 AM
magneto259
Nov 20, 2009 04:44 AM
