Jet-A1 as cheap alternative Diesel fuel.
Humm... I might just have to go over to the local airports and do some asking around... Been watching the DRMO for a surplus fuel or water container as i was thinking about doing the veggie oil thing anyway
Major "C" inspections, work on fuel systems, weighing SOP's etc require that fuel tanks be drained and such fuel may not be replaced in Commercial (or any other) aircraft as it is "deemed" to have been contaminated. To what extent depends on how clean and dry the drums and containers were! Since they are regularly used for this purpose it's not an issue in a vehicle as you are gonna filter it anyway.
I'm sure you will be aware that it is illegal to use dyed "off highway" diesel in a road vehicle but JP8/Jet-A1 has no dye and like veg oil is still something of a gray area .
Jp-8
When I was in the military we first started using JP-4 in diesel powered equipment around 1986. The military switched to JP-8 later on. We use JP-8 in all diesel powered equipment now. The only problem we had was with some of the diesel powered vehicles were hard to start. I don't know if that is still the case. The reclaimed fuel is not cantaminated, it is pumped out of the airplanes by the refueler trucks, and passes through the filters on those trucks. Smaller amounts of reclaimed fuel are generated by fuel-cell repair activities when the cells are opened for repair. Reclaimed fuel is burned on an Air Force base in ground equipment.
I have run Jet A in my 96 Powerstroke for years with no problems. in fact, for a year straight I was running Jet A mixed 2-3% approx biodiesel (B99+) and it actually idled smoother and started easier. Power loss was negligable, but i did notice a bit of drop pulling my big fifth-wheel.
I had to have a head gasket replaced (unrelated, coolant leak) and when they had the head off, the techs were blown away at how clean the cylinders pistons and head chambers were, at almost 300k. so I would say it aided in keeping the engine clean.
I happened to work at an airport facility, and whenever we brought a truck in for a fuel filter change, or brought a plane in for maintenance, we had to drain the fuel, and per FAA regs, you cannot re-use that fuel, even though it is perfectly clean. really a waste if you ask me, but didn't hurt my feelings none!
If you hit up some of your local FBO's (small airports) you may be able to ask them for their "Sump Fuel" most places have to pay to dispose of it, so often times if you provide a clean container, they can "dispose of the waste" in your container, so to speak. they can't give it to you do to Post-9/11 regs, but they can certainly "dispose" of it. That is what I do, when i don't get it from work.
#28
