Help with my 2001 V-10, slight miss, no codes.
Old 07-20-2017, 09:54 PM
Slowped's Avatar
Slowped
Slowped is offline
Question Help with my 2001 V-10, slight miss, no codes.
I have a 2001 Excursion with the V-10. Two weeks ago, the upper nipple on the radiator cracked and I overheated. Was towed home and replaced the radiator with a quality aftermarket one. I then drove to the whiz wash and cleaned the antifreeze off of the engine.
Immediately I noticed a slight "miss" when cold, particularly when backing out of my driveway. I have no lights on the dash and it is throwing no codes. The miss gets much better (almost gone) when the truck is warmed up.
I am at a loss, does anyone have any suggestions? Thanks.
Old 07-20-2017, 10:38 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
odds are that you got water into the rear spark plug holes. the recesses can collect water and if the seal around the COP's isn't tight, the water will leak and cause a short while driving.
best bet is to remove the back 3 COP's on each side and dry the recess out. it only takes a little bit of water to cause the issue.
I also wouldn't be surprised if the issue solves itself over the course of the next few days as remaining water boils off. As far as check engine lights, unless you have a California Excursion, your OBD-II is actually a dumb OBD-II. The Excursion didn't meet Federal requirements like small vehicles did. Only the Cali versions did. That's why it takes a massive miss to trigger CEL
Old 07-20-2017, 11:20 PM
Slowped's Avatar
Slowped
Slowped is offline
Thanks, I'll take a look at that tomorrow. I do live in NV, the weather hasn't been under 110 for the past few weeks and I've put about 400 miles on the truck since it started.
01f250v104x4
1999 to 2016 Super Duty
02-05-2017 04:24 PM
fordboy67
05-27-2015 01:14 AM
waynenichols
01-12-2015 07:18 AM
v10excur00
Modular V10 (6.8l)
04-15-2013 09:04 PM
crfrider
05-09-2011 06:40 AM
Quick Reply: Help with my 2001 V-10, slight miss, no codes.
