rims???
rims???
not quite at this point yet but throwing around some ideas especially after i mounted one of my buddies set of cragar ss rims to the truck, was going to originally do the steel rim thang but i`m kind of thinking something else now, truck is going bright orange, thinking of either supreme rims, cragar ss, would like it to look old school with a twist?? what do you guys think?? anybody have pictures of these trucks with supreme rims on them??
I,m going with cragars myself in fact I just ordered a pair for the rear just 5 minutes ago. There are a number of guys on here with cragers and they have them in their galleries. I,m sure they will kick in some pictures for you. I went with the 15x8 with 3 1/2 inch backspacing.
Summit sells them on line or by phone if you need a set backspaced thats not listed.
Received 1,353 Likes
on
I have used a set of Cragar SS wheels on my truck as rollers during the building process. I intend to use American 200S wheels when it finally hits the street. The picture below has the truck with both styles on it. I had just polished up the lips on the 200's and I had to stick them on to see what they look like. The Cragars are 15x10 and the 200's are 15x8. The rear fenders are 3" wider than stock and the rear measures 58 1/2" flange to flange, and the wheel backspacing is 4".
I don't have any clearance issues on the rear fenders with this setup. I know your truck is bagged and you have the wider fenders. If your rear measures close to 58" you should be able to drop it down and not hit your fenders. I guess I'm assuming that you want to run wide wheels.
I guess I'm old school on wheels, but I don' think you can beat the look of polished torque thrusts on these F100's. And if you're into the bigger dia. rims, I think american is making the torque thrust in bigger diameters.
Andrew
Andrew
on
jade79
38
08-25-2020 10:02 AM
bememe
30
03-19-2009 07:30 AM
