9 inch brake offset - very confused
next question is can you fit a socket on the bottom nut on the front side, or is the pinion in the way? Maybe you have a 65-66 Mustang 8"? (I pretty much doubt that, though)
Could be an early mustang center section, and truck style tubes and axles, and brakes....lol.
Unfortunately, all of mine are buried in the snow out back.
Ford 9 inch junkyard Questions.. - Pro-Touring.com Here's a pic on this link that shows a 1969 Cougar 351 9" which is what your tag indicates. Notice the tapered ends. If your's is a big bearing, it wouldn't have tapered ends. Should be 3" all the way. Ford 9 inch junkyard Questions.. - Pro-Touring.com
You can see the pumpkin has two dimples with the fill hole and the axle ends have the two holes with countersink in the middle
And here are all the measurements:
Axle flange-to-flange width: 57"
Axle tube Outer Diameter: 3.125" all the way (no taper)
Bearing size was about 3.15" OD
Flange hole spacing: 3.15" horizontal, 2.375" vertical
Bolt pattern is 5 x 5.5"
28 spline - the axle is tapered
Doing some google searching, the 57" axle width suggest that this is the 57-72 pickup?
High Q Ties - 9" Ford Information and Identification
FORD 9
So with all this, why does my axle offset measure 2.00" when you would expect 2.36"?
And thanks again for all the help.
artscott61
13
04-27-2021 01:10 AM
mull3915
06-23-2017 01:59 PM
myfatherinlaws56f100
01-30-2017 08:55 PM
Danthemanmj23
05-30-2016 12:59 AM
fatheroftwo
03-10-2016 11:56 AM
