stupid battery
stupid battery
so was installing my CB radio into my truck tonight what a pain in the *** that is with the center console shift!!!
so i left the truck on so i can listen to the radio i had the door open so i had to move it to the notch before you crank the motor so it wouldnt ding me to death. it took maybe 3 hours from 4 to 7 and at 6 i noticed the auto lights came on even tho it was still light. turned them off ant cept workin. finnished at 7 tsted it and everything was great. went to crank up and move back to the front yeard and just "tick tick tick tick"
'Fing A!'
why would my truck die after just 3 hours of light battery use
im getting a bad *** battery tomorrow. any suggestions?
'Fing A!'
I just went and bought the biggest Interstate battery I could find for $120 last year.
at least 800 CCA, and 1200 CA I believe
I'd look for something similar. Help crank the 5.4 over, and also give you a little bit more juice when doing things similar to what you described. Bigger does = better in this category IMO
yup thats exactly what i did. didnt know it was taking that much power ... now i know
i had a similar situation happen to me, twice.....freakin thing died after an hour of running the radio with no other lights or anything on....then more recently i left my headlights on to light up a friends driveway so i could spread some salt so the old ******* wouldnt slip on the ice....not more than ten minutes later i get back in to start it up....click....dead.....gonna go get a real battery...i love my ford...but motorcraft batteries suck.
These newer vehicles use up a lot of battery just sitting for several days. The computer is holding data, your radio/cd player is holding data etc. I met a guy that's a service manager for a Toyota dealership (not his fault) who said it's not uncommon for a battery to get too low to start the car after sitting for a week. So bigger is better.
batterys
In my experience, new car batterys are cheap and will not last. When it is replacement time I will go with an Interstate. Why? Lift the wornout battery coming out of your truck and then lift the interstate you are replacing it with. Its about lead. Cheap equals no lead and quality equal more lead plates. Its hard to save money buying cheap products. i have an 07 so I'm about due!
batterys
battery life is more a function of where you live vs. the quality of the battery. There are some better brands out there, but modern manufacturing pretty much has erased the huge gaps between the brands. Now it's about Brand Name and the associated warranty you get vice "quality"
cold climates eat batteries. plain and simple.
hotter climates not so much. I've seen batteries go well in excess of 6+ years back home in Texas. The batteries don't have to work so hard in the heat, so they last longer
