6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
New 6.4 Customer Satisfaction 09b08-Injectors
Old 02-20-2009, 03:34 PM
goneon66's Avatar
goneon66
goneon66 is offline
another forum posted this Customer Satisfaction 09b08 concerning 2008-2009 F250-F550 6.4 PSD's and possible replacement of injectors. i immediately called my dealer and the service manager has NOT even heard about it.
anybody know anything???
66
Old 02-20-2009, 05:31 PM
PowerStrokeHD's Avatar
PowerStrokeHD
PowerStrokeHD is offline
CSP 09B08 affects certain '08 and '09 model year trucks with 6.4L built between 05/14/08 and 11/07/08 and is for injector replacement due to the possibility of premature injector o-ring wear/failure. As a result, fuel could leak into the crankcase. Approximately 8,000 vehicles are affected by this program and the program will be in effect through 03/31/10...
Affected trucks will show up in OASIS and there is a list that tells which injectors need to be replaced on affected trucks based on individual VIN number. In some cases it may only be one, in others it could be all 8 or it could be some where in between...
Owner notification by Ford will be a phased process since there is not a sufficient supply of injectors available to service all owners at this time. The phase mailing will be prioritized by axle ratio with numerically higher ratios being first since they are the most susceptible to the issue...
Old 02-20-2009, 06:17 PM
firemansdiesel's Avatar
firemansdiesel
firemansdiesel is offline
Could this be the problem some owners are complaining of making fuel in the oil or making up to 6% of fuel on oil analysis reports?
Old 02-22-2009, 08:19 PM
sawtooth's Avatar
sawtooth
sawtooth is offline
yes this is most definitly one of if not the main issue for people making oil.
Now, where can I find the list for the effected VIN numbers?
Old 02-22-2009, 09:11 PM
PowerStrokeHD
This is definately a issue that would cause trucks to make oil, but I do not believe it is the main or original reason based on the build dates of the affected trucks. The reports of trucks making oil were seen well before the build dates of these particular vehicles...
Old 02-23-2009, 08:22 AM
caprang's Avatar
caprang
caprang is offline
The build dates for this program are all job 3 trucks and I seem to remember that early job 1 trucks had the worst problem with fuel in the oil.
Old 02-24-2009, 02:48 PM
Bobby Light's Avatar
Bobby Light
Bobby Light is offline
*The VIN list is 49 pages long*
If you want to pm me your vin, I can check it for you.
Old 02-24-2009, 03:26 PM
rmosso1's Avatar
rmosso1
rmosso1 is offline
If you will tell us why you call yourself "CUMMINS Bobby Light", I will apologize for earlier caustic remarks, and ask you to check my VIN: 1FTWW33R08EC63771 .
I just don't understand, if as I read somewhere you have (3) Ford diesels you call yourself CUMMINS, which to me are swear words.
Old 02-24-2009, 03:33 PM
Bobby Light
76 - 6.4's
1 Cummins Ram
Guess which one I like the best! (btw, I didnt come here to **** in anyones cherrios, just help and gain more knowledge)
your vin was not found on my current list.
which does not mean you are totally in the clear, 3 of my trucks are not on the list but have had new engines because of fuel in the oil.
Just watch it closely.
Old 02-24-2009, 03:41 PM
rmosso1's Avatar
rmosso1
rmosso1 is offline
As I stated above, please accept my apology. If you own 76 vehicles with 6.4's you are the MAN!
My opinion is that the regen process forces more oil into the chylinder when called for. Obviously this is done to get fuel oil to get out the exhaust valves (3). With so much compression, and so much fuel pressure, with no place to go, a tad can get thru the rings and to the crank case. Probably why they put in a 4 gallon oil pan. My bet is that you could probably run with 5 gallons of fuel/oil in pan and hurt nothing. Remember the injectors fire from oil pressure. Just my simple opinion. Now let the guru's chop me up, because I deserve it for taking a shot at you. Sorry,
Old 02-24-2009, 03:45 PM
Bobby Light
The injectors fire from a plezo actuator in the injector (electronic)
Old 02-24-2009, 03:54 PM
Bobby Light
btw, I asked for it when I put that cummins avatar up.
hah
Old 02-24-2009, 04:11 PM
UGA33's Avatar
UGA33
UGA33 is offline
Do you own the company that uses them or work for it. Not that it matters, just curious.
Old 02-24-2009, 04:12 PM
Bobby Light
I apologize, company owns them, I am just responsible for them.
Old 02-24-2009, 04:13 PM
rmosso1's Avatar
rmosso1
rmosso1 is offline
Yep, and also four valve per cylinder. Just checking you out. Don't want to give a a potential troll, which you are not, any "priveleged communications".
I love this site for pictorial description of our engines:
http://turbodieselforums.com/diesel.pdf
Welcome aboard. You have to run into a guy by the name of rob_nc or something like that. He is knowledgeable in so much about this new generations of diesels.
Welcome aboard, and change that avitar !!!!!
Quick Reply: New 6.4 Customer Satisfaction 09b08-Injectors
