Bar's Leaks Rear Main Seal Repair?
Hey Ya'll,
I just got an e-mail from powerblocktv where they are advertising Bar's Leaks Rear Main Seal Repair. I have a small/minor rear main seal leak. You know, just leaking enough to aggravate you whenever you change the oil or just look under the truck.
Has anyone used this product before and does it work?? One 32OZ bottle is supposed to treat 4 to 6 quarts of oil (any kind of oil, and for gas or diesel). If I were to try it, do you think it would hurt my 7.3 with 79K miles? And then would I use 3 bottles of the stuff (@ 4 quarts), or 2 (@ 6 quarts). I'm reaallyy skeptic about what I put in my Ex... I use rotella syn now and I'm due at 80K. Need advice from you veteran FTE members.
Here's the link to the page...
New Product Alert - February 19th, 2009
Before you start doing anything like that, you need to look a little closer at this. The rear seal on the 7.3 is very rare to go out. You need to look on top of the engine with a flash light in the valley for oil. The oil from the valley will drain out the back of the engine and run down to the inspection plate. I bet you will find oil in the valley, if you do let us know. Good luck.
It's definitely the rear main seal. I had the ford techs tell me that with my CPS recall and then again by a very well respected mechanic here in Jax. I just replaced all of the O-rings on my fuel bowl too, and the valley is clean as a whistle. (easy off oven cleaner is the BOMB!)
I still have several weeks B4 the oil change. I'm just a perfectionist on my truck and HATE any kind of leak. If no one's heard good news about the stuff to share, I'll just keep wiping the area clean every 5K....
Bar's Leak cured a radiator leak I had on my old 92 F150... (I miss you Bubba!) Should of kept that truck!!
I was just hoping for the same results here but I wont use it unless I hear FTE members who've had success.... Thanks for the response Rick...
I can't remember if it was Bars or not but i used a sealer similar to that on my old 150's power steering unit and it worked great for about 6 months then started to leak like a sieve.
Im sure the newer gasket materials are more withstanding than the old but i believe the theory is that it causes the gaskets to swell thus stoping the leak but it will also weaken it over time.
Rear Main Seal
I am one of the people that actually developed that Bar's Leaks Rear Main Seal product along with being a PowerStroke owner myself. There are no particles in this product to plug a leak, like a radiator stop leak. It has a special seal swell additive which we worked on with Lubrizol that is specifically designed to not do anything to newer rear main seal materials, but will take older seals that have started to harden and shrunk, and make them soft and pliable again giving a few thousandths swell. What is really different about this product is the polymer we use that will even help if the seal is just worn or if there is a groove worn in the crankshaft. Though it can't stop them all, with the millions of bottles we have sold the past few years, consumers have had very good luck with this.
Can you please give me more information on this? We value our brand and reputation very much and would like to know what has happened to find a solution to why it happened if possible.
Subscribed
I wouldn't use it on a diesel that uses engine oil for the injectors. Too much can go wrong.
Just fix the rear main, or like others have already said, MAKE SURE you research what the problem really is, the 7.3 is known to be diagnosed as having a leaking rear main, and yet, it's somewhere else.
