E89e-6015-ad
Old 02-19-2009, 11:33 PM
Universal Dad's Avatar
Universal Dad
Universal Dad is offline
E89e-6015-ad
I have a sand rail with a Cortina engine in it. I am trying to replace it with a 2.3L. I bought a short block with an engine number E89E-6015-AD stamped on it. I believe it is a '89 block, but what do the rest of the digits mean?
Also, I want to set this engine up to be as simple as possible. Can I have it fitted with a regular distributor, and carburetor?
Thanks,
Universal D
Old 02-19-2009, 11:43 PM
Bdox's Avatar
Bdox
Bdox is offline
Welcome aboard UD!
If you don't get a response soon, try the Ranger forums. There is plenty of knowledge and helpful people here.
Old 02-20-2009, 01:54 AM
kernel-panic's Avatar
kernel-panic
kernel-panic is offline
The '89 blocks can be set up with normal aspiration and regular / electronic (Duraspark II) distributors. You can even buy an aftermarket intake or find a carb intake from a junkyard, etc. You'd probably have to use at least an '81-'84 head and intake manifold for carbureted setup:
The Ford Ranger 4-Cylinder Lima Motors - The Ranger Station
Hope this helps
Old 02-20-2009, 01:56 AM
kernel-panic
I posted a response... awaiting moderator approval...
Old 02-20-2009, 10:37 PM
Universal Dad
2.3L Assistance
This does help. Thank you very much.
Old 02-21-2009, 05:14 AM
kernel-panic
No problem!
TexasGuy001
20
05-21-2021 09:20 AM
saltbranch
5.0L Coyote
05-27-2017 01:40 PM
balboni
08-18-2015 05:09 PM
moodybo
04-05-2006 08:02 PM
TCTOOL
12-20-2001 12:43 AM
Quick Reply: E89e-6015-ad
