What do I need to do to add the top alternator?
My truck only has the single alternator. I want to add a secondary battery bank to power a 1000W inverter and would like to install a high-amp alternator in the top position to charge these batteries entirely isolated from the the starting batteries without installing a battery isolator. So what do I need to do to add the alternator? I know I'm going to need to change the serpentine belt and top radiator hose, will I also need to add some wiring harness or does it already exist? What about the bracket and alternator, what do I need to buy?
Thanks in advance.
Thanks in advance.
The 2nd alternator is actually a lower alternator. You'll need the mounting bracket and wiring, usually from a wrecking yard. The other option would be to look into a high output alternator to run as a single. Check with DB-Electrical and see if they don't have something that will fit with what you need.
I don't have the info you seek, just some observations.
Back in the day, dual alternator set-ups were crap. Today. on ambulances and such, we onlo use singles, althought it's a high output alternator.
However, should you add a second alt for a SEPERATE bank of batteries, that should be no problem. Just make sure there is a voltage regulator involved somewhere.
Thanks in advance.
Thanks in advance.
Anything we say here would only be relevant to a 7.3 diesel.
Should we assume that?
Pop
If I ever need another one, I'm getting one of these:
High Output Ford Alternator, Large Case Alternator Upgrade for Ford 7.3l, 6.0 & 6.5 Power Stroke Diesel
Probably an HD 160A...
Don't know about installing a second alternator, but, as an option, those alternators listed in Izzy351's post are pretty tough. You could wire them together, and use an isolator, or you could get a battery disconnect switch and shut the auxillary batteries off when the truck is off. Just a different idea that would accomplish what you're looking to do. #1 gage welding lead would be big enough, and is probably cheaper than battery cable. Can be found at your local welding supply shop.
Yep, that's right. The only way it gets tricky is when you want to run duals charging THE SAME batteries. If you were planning on running a completely separate battery, the second alt would work perfectly without isolators, etc. For me, I don't run enough accessories to make it worth it, so just an upgraded one with high-idle on my chip to keep the voltage up is all I need. I have an RF amplifier that pulls 90A peak by itself, so the stocker is a bit light, but I don't need a separate system for it for as much as I use it.
LipschitzWrath
22
08-14-2017 05:22 AM
cadjak
35
09-16-2015 08:12 PM
gramicko
01-16-2014 12:11 AM
seamonkey49
Escape & Escape Hybrid
03-01-2006 08:41 AM
