Lost my ignition key!
Old 02-12-2009, 10:14 PM
boggerted's Avatar
boggerted
boggerted is offline
My friend has a 1986 F150 and he lost the ignition key for it. So, Im assuming he needs to get a new lock cylinder for it. The problem i9s, every instruction set I find requires you to turn the key to the run position to remove it, which I obviously cannot do. Is there another way?
Old 02-12-2009, 10:28 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Bern_F150_4x4 is offline
Round up as many Ford ignition keys that you can and give 'um a try... I was surprised to find out that the key to my parents Ford wagon also fit the neighbors Mercury, how convenient! Later on I bought a tilt colum for my '73 Mustang and did not need to re-key it! It’s worth a try…
Old 02-12-2009, 10:51 PM
Ritechous_23's Avatar
Ritechous_23
Ritechous_23 is offline
The best and probally the cheapest way to go is to go to the ford dealer and give them the vin # off the truck and they can match the # to a key pattern and cut a new key.This type of thing happened to me and I went to the dealer.
Old 02-13-2009, 04:58 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,684 Likes on 1,360 Posts
It may not be the best, but the quickest easiest is to take a large screwdriver or chisel, and break the chrome piece off. It's not that hard to do. Then you can reach in there and release the pin, and take it out. The local parts stores have the new cylinder locks in stock. They will give you a new set of keys to go with it. Here's a link on how to do it.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old 02-14-2009, 05:38 AM
srercrcr's Avatar
srercrcr
srercrcr is offline
... and remind your friend to put a spare underneath somewhere.
Old 09-29-2009, 12:47 PM
Alcaeus's Avatar
Alcaeus
Alcaeus is offline
sorry for drudging up this old thread. I took a hammer and screwdriver to my chrome piece and I still cant figure how to get this cylinder out!
Anyone have a how to?
Old 09-29-2009, 07:47 PM
Roanoker494's Avatar
Roanoker494
Roanoker494 is offline
You have to use something pretty flat and reach in between the steering housing and lock cylinder. You should be able to find the button easily, there should be a hole on the outside of the column where the button is located. I have also used a good bit and drilled the button out before. You have to have very sharp bit to do this.
MD11Drvr
02-21-2014 06:48 AM
Obtuse1
17
01-25-2014 12:29 PM
jason6432
1997 - 2003 F150
12-28-2011 12:45 PM
JimJames99
07-15-2006 01:50 PM
Quick Reply: Lost my ignition key!
