What is the diff in Willys & Ford Flathead?
Old 10-30-2010, 10:00 AM
Kalve's Avatar
Kalve
Kalve is offline
What is the diff in ****** & Ford Flathead?
I have a 74 F250 with 390/4 speed manual & Holley 600 4 barrel an I am looking at a 4wd vehicle easier on gas for back & forth to work an so on. I am looking at a 1946-1949 ****** wagon with flathead. But I was wondering what is the difference between the ****** & Ford flathead?
Old 11-01-2010, 11:29 PM
1952's Avatar
1952
1952 is offline
Are you talking the flathead Ford six verses the ****** six? If so, probably not much. The early ****** six was sold out to IHC in the mid 30s. This engine, IHC's Green Diamond, soldiered on into 1949. The "new" H series Ford debuted in 47-48 and was not much different than the IHC, in fact I've heard that Ford somewhat copied the IHC Green Diamond, especially with the cam-driven oilpump/distributor combination. So, if the ****** stayed true to its roots, then it shouldn't be much different at all.
If you are comparing the flathead V8 to a ****** six, or even 4, then there is obviously
more cylinders and the whole bent 8 concept that ****** did not have.
Unless it has overdrive, I doubt that a ****** wagon would offer a whole lot better mileage. I do stand to be corrected, though.
Old 11-01-2010, 11:35 PM
Kalve's Avatar
Kalve
Kalve is offline
I am looking at buying a 52 or 62 ****** wagon an they says that one has a flathead & ones got a Super Hurricane. So there would be no difference between the two in the flatheads an the Ford 6 cylinder would be bout the same as the Hurricane engine. I am looking at it in case I have to put the body on another frame. The two I am looking at at look so so body wise an I figure the frame is probably bout the same.
willy j
Electrical Systems/Wiring
01-23-2017 06:42 PM
Cg willie Willie
01-18-2017 09:14 PM
willys392
11-07-2015 07:21 AM
willis72
1999 to 2016 Super Duty
12-07-2014 10:11 PM
willy3486
09-22-2013 10:51 AM
Quick Reply: What is the diff in Willys & Ford Flathead?
