Good
Good
Just installed a set of new O.E.M.-type replacement mirrors on my 1990 Bronco.Installation was easy-no drilling,just unbolt the original ones,and replace with the new pair.These mirrors/brackets look factory.The only thing is I used Ford's original allen head bolts,instead of those included in each mirror kit.Installation took all of 15 minutes.You'll need a 5/32" allen head to get the 4 bolts loose(2 up top,2 close together on the bottom of mirror bracket).Once these are out,just carefully remove the whole mirror assembly.You can either re-use the gray,rubber mirror "gaskets",get new ones through a Ford dealership(or aftermarket supplier...),or use the black,plastic ones supplied in each kit.I decided to use these,although the O.E.M. gaskets are still in useable condition.I first attached the arm/bracket to the door,then added the mirror head.One side,then the other.Once both mirror assemblies were mounted on the truck,I got inside to adjust each mirror,then with a small phillip's head screwdriver, tightened a few screws underneath each mirror head.They look factory.This was a very nice upgrade.They are KoolVue mirrors,part # FD11R-L,and fit either side.I ordered them,and had them at my doorstep within a week. I was very pleased.:7
