temperature sender question
Old 02-11-2009, 08:27 AM
turnrjr's Avatar
turnrjr
turnrjr is offline
Is a temperature sender specific to 6 or 12 volt systems? I need one. Currently the truck is 6 volt but will likely convert to 12. Thanks
Bob
Old 02-11-2009, 10:29 AM
Old F1's Avatar
Old F1
Old F1 is online now
Yep, I think so, but nothing is ever that easy, but what about the dash gauge, if it’s electric the ohms have to match wouldn’t they?
(Matching ohms are really hard to find, kind of like smart hockey goalies)
I think there are many threads about this; did you have any luck trying various search headings?
Old 02-11-2009, 10:50 AM
hotrod351's Avatar
hotrod351
hotrod351 is offline
i know for a fact that if your system was 6 volt then get a 6 volt sending unit. i had a 55 f100, 6 volt positive ground, converted it to 12 volts and bought a 12 volt sending unit and installed it, no way did it read right. i was at a wrecking yard and saw a old v8 Flathead and pulled the sending unit out of it, my gauge worked great after that. a shop told me that the gauges didnt know the difference. id check with some of the old timers that are familiar with this to make sure but i know what i was told and what worked for me.
Old 02-11-2009, 11:20 AM
oldguy829's Avatar
oldguy829
oldguy829 is offline
Temp sender.
Hotrod has it right. The sender and gauge are a matched set. Voltage, polarity and ohms resistance. Not just min and max ohms, but the linear curve, or you get false readings. Mixing and matching is nearly impossible.
Get a sending unit that matches the gauge (ie, original for the vehicle and engine that came in it.) The sender doesn't care what engine it is in. It just translates heat into ohms resistance. When you switch to 12v, get a reducer to keep the dash gauge at 6v.
Old 02-11-2009, 11:26 AM
gearhead1952's Avatar
gearhead1952
gearhead1952 is offline
All you need is a 6v regulator that bolts to the back of the gauge and can use original gauge and sending unit. You buy one regulator for each gauge so that makes a total of three, water, oil and gas. I did this on a 51 panel and kept the original gauges and mounted the flathead sending units into brass adpaters onto the late model engine. Works great.
fifthavenueinternetgarage.com sells them among other places.
Old 02-11-2009, 11:31 AM
hotrod351's Avatar
hotrod351
all i did on my conversion, was, 12v generator and regulator, 12 volt lights, windshield motor and i believe heater motor, coil and i think thats it. left the 6 volt starter and never had any problems, plus my 55 was my work truck at the time so i drove it every day for years.
turnrjr's Avatar
turnrjr
turnrjr is offline
Thanks guys. Now I need to ask Bill number dummy about the original part number. My book shows the illustration number but can't find the corresponding part number. Thanks again.
