How to defeat low oil pressure fuel cutoff?
I have an 83 Class C motorhome built on an E350 Econoline with a 460ci engine. It is very slow starting when it sits a few days and I'm worried about burning up the starter. I'm told that the electric fuel pump has a low oil pressure cutoff and that it might be possible to rig a temporary override switch to facilitate starting.
Has anyone done that?
This sounds more like the electric pump is not running when the key is first turned on for the 10 seconds to prime the carb and the pump is only running once the key is in the start position (at lower speed because the starter has dropped battery voltage). I see an easy cure, a spring loaded bypass switch to run the pump before cranking, or better yet, fix why the pump doesn't do its short run in the key on position.
synergy141
25
10-04-2018 11:15 AM
Redwolfbuddy
07-01-2013 12:07 AM
axman_F250
05-13-2011 08:21 PM
SPENCERN
08-29-2005 07:29 AM
