2005 Plug NIGHTMARE!!
Well, after reading several posts from here, and reviewing the RSB on how to change plugs on my 2005 Expedition, I decided to give it a try.
2005 Expedition 5.4L 3 valve, 72k miles
Well, I got the first one out without much issue. Definately harder than a typical change, but adding the penetraiting oil was a big help.
Second one started well, and was acting like the first. Upon removal, it was only the top of the plug. the shield and the ceramic were still in the head. I put the thing back together and took it to the dealership.
They informed me they have to remove the body, or the engine to get them out.
$1,500 is the estimate!!!!
BULLS#*@!!!
Any thoughts?
Eric.
BULLS#*@!!!
Any thoughts?
Eric.
$1500 is a rip! Stupid stealerships....
Not to sound ignorant but what exactly do you mean by "top of the plug"? Do you mean the little metal knobby thing, or the body? I'm confused b/c you said the ceramic was still in there, which to me is the body of the plug. If the body is still in there I would think you could still get it out. I found that using a regular socket worked better than a plug socket b/c it was easier to feel that it actually had a hold of the plug base. Does that make sense?
Hey Kitty,
On the 5.4, the plug has a very long electrode and a "shield" that extends a ways below the threads into the cylinder. So the hex part of the body came out fine, but the shield and the electrode were still in there.
The problem is that I none of my local shops were very familiar with this issue. Only one seemed to understand, but didn't have the tools, and told me they had not performed the replacement before. The dealership knew immediately what was happening. The difference in the labor rate was $92 (dealer) $75 (repair shop). for the $100 - $150 difference, I would prefer to have the dealer do it.
My complaint is that Ford hasn't acknowledged this is an issue, other than to post a TSB on it. I am going to call and file a complaint just in case they decide to do something.
The sad part is that between my Taurus having tranny problems, and the Expedition having this, I may not buy another Ford. I am that furious about it.
Thanks for listening.
Eric.
Eric.
I agree with you guy's. If I would have realized the cost, I would have drove until 100 -120k miles then had the plugs changed by the dealer. At lease then you would only pay the $1500 once.
They did say that after they install the new plugs with Anti-seize, they have not had another problem.
I will keep you posted on how it goes.
Eric.
Eric.
Here's an update: They did remove the Cab in order to access the plugs. The tech broke 7 of the 8 plugs! Because he removed the cab, he may have not followed the procedure, not sure. $1600 total.
Oh, did I mention the window regulators need to be replaced? They lubed them but it made the situation worse, so that will be another $500, and the rear wiper pivot needs to be replaced for another $250!
I am really beginning to hate Ford!
Eric.
Eric.
The window regulators are about $130.00 each, and can be changed in about an hour if you are mechanical.
I wrote a full post with pics, but the pics were deleted. The regulators are made of cheap plastic with cables. It is designed to fail.
Whatever you do, do not try to lower your windows if there is a chance of them being frozen or stuck. The cable will jump off the spool and ruin the whole regulator.
And Ford wonders what they are in the shape they are in. I just sold my Expy after 7 months on the market.
Here is the post detailing how to change the regulator, but no pics.
https://www.ford-trucks.com/forums/7...regulator.html
They may call it "removing the cab", but in essance what they do is disconnect the driveshaft and all the engine connections and lower the engine and suspension out the bottom. Now they have some room to work on the engine.
To take the plugs out, they had to remove the body from the Chassis?
