wms-wms
Typically you see axles width measure from axle flange to axle flange, then there is an additional brake offset. Here is some info i pulled from the net for you. WMS takes into account the brake offset.
Brake offset-this is the measurement from the outside of the axle flange to the edge of the bearing retainer plate that bolts to the housing. Large bearing 9" housings have a 2 3/8" brake offset, and small bearing 9" housings have a 2 1/2" brake offset. There are also others such as 2" and 2 1/4", but you better have the drums and backing plates that go with those offsets or you could be in trouble as far as finding brakes to fit.
F-150 9" axle is 65" WMS to WMS, with a pinion offset 4" to the right
i dont know what year that is for though
So, does anyone know what the axle flange to axle flange is on the 9 inch out of a 72 F100?? Im not sure that was posted as the original poster asked..
BTW- matejcekautoworks, since this was your last thread you posted to, can you please see this thread and get back to us. https://www.ford-trucks.com/forums/822520-warning.html
havent made it to the rear end yet but came across this.
https://www.ford-trucks.com/article/...Lowering_.html
