Something is loose in my front suspension
Its the radius arm. When I looked under it the first time, I noticed the bushing back there was not centered. Looked to be falling out. The more I read about it, didnt know it was called a radius arm, the more it lead to being the bushing.
Rattles over small bumps, dirt roads and snow covered streets. Doesnt look like a hard job. Ive done a frame off resto on a GM a body and did the front axle u-joints on my 79 4x4 (rusty pile of ****) so this should be a piece of cake.
I had a similar problem on my truck several years ago. It turned out to be the lower retainer on the coil spring. I'm referring to the nut and washer shaped peice.
I have also experienced the shock problem. Mine was because the bushing in the lower shock mount was shot. I replaced the shocks and no more of that annoying noise.
Its not technically a hard repair just a pain in the butt, for me anyway Ive taken a whole ttb 2wd front end out of a truck in little time but the 4x4 is a little more involved in general.
