differential codes.
differential codes.
>Hi. Could someone please decode the
>numbers on my rear diff.
> 0 8 8 8 7K12
>5806D I'm trying to find out
>what gears the 88 f150 4x4
>had front and back. (the codes
>are from the rear) Thanks
inside the door is a sticker that has a number in the axle column. Retreive the number and I will tell you what you have.
Also, you will get a quicker responce by posting in the 80-96 column.
> 0 8 8 8 7K12
