1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
manifold stud recall 03 ,F-250
Old 01-27-2009, 10:15 AM
jasper007's Avatar
jasper007
jasper007 is offline
Anyone know if there was a recall for the cheap exaust manifold studs that disintregate and break off at the engine ??
Old 01-27-2009, 11:42 AM
Silentst2000's Avatar
Silentst2000
Silentst2000 is offline
There is a TSB for the 5.4 2v engine where you are supposed to replace the effected bank with stainless steel studs and nuts under TSB 05-5-4 and is covered under emissions warranty. No recalls for it though.
Old 01-27-2009, 04:01 PM
winged1dur's Avatar
winged1dur
winged1dur is offline
Any idea if my 1999 F250 LD with 90,000 miles would still be covered under this TSB? I just got a quote of $1300 to replace both manifolds.
Old 01-28-2009, 09:48 AM
Silentst2000
A tsb does not extend any warranty coverage. If you still have federal emission warranty coverage then those components should be covered. The tsb lists 99 to 04 f-250's with the 5.4 2v engine. Call a dealership or two with your vin ready and ask them when your federal emission warranty expires.
Old 01-28-2009, 09:50 AM
Silentst2000
I think it is 8 years 80,000 miles but I'm not sure.
Old 01-28-2009, 04:42 PM
Sooper-Doodie's Avatar
Sooper-Doodie
Sooper-Doodie is offline
Federal emissions warranty is 8 years/80k. You are on your own to repair it. Buy a 90* drill, some good drill bits and some easy-outs and have at it.
BTW: I bought a set of headers off ebay for under $130 and used SS bolts. Haven't had a problem since. I even had one of the bolt holes drilled crooked from the factory, a stud was put in it and it was broken off deep in the head since it was new. I couldn't do anything for this but, because that hole was between two others and my header flange was nearly a 1/2" thick, I didn't even install a bolt in that hole. 15k and still no leaks.
RVHATETHEMALL
08-22-2016 08:53 AM
DesertSmoker
Modular V10 (6.8l)
04-28-2016 03:20 PM
johnfin1
07-09-2015 08:29 PM
construct30
Exhaust Systems
05-30-2015 07:00 AM
pophauler
07-24-2004 08:30 PM
Quick Reply: manifold stud recall 03 ,F-250
