miles with leveling kit
Old 01-25-2009, 09:56 AM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
I was just wondering how many miles you guys have put on your trucks after installing a leveling kit, and if you've had any premature failure of any front end components.
Old 01-25-2009, 11:02 AM
Still Smoking's Avatar
Still Smoking
Still Smoking is offline
I have had mine on since August I believe it is. Put on 8-10000 miles and nothing has gone wrong yet. I got the 3 inch leveling kit and every one was worried about the cv shafts. Havent had a problem yet with them.
Old 01-25-2009, 12:13 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
installed spring 07
over 15,000 miles now with it installed, about 25,000 total mileage on the truck
0 problems...just get the alignment done ASAP so you don't ruin your tires
btw, I know quite a few guys with 50,000 + miles on their trucks with a leveling kit installed.
some naysayers say the leveling kits eat up ball joints...while partially true, it's actually the roads you drive on that do this. If you have decent roads, you'll be fine. You have crappy roads, your ball joints are gonna go bad with or without a leveling kit...the leveling kit will just make it appear a little quicker.
Old 01-25-2009, 02:16 PM
bwep's Avatar
bwep
bwep is offline
Auto Spring
I'm a little shy of 50,000 on my 2" auto spring. I have original tires on the truck still. It went in for front hub work and when I looked over the repair bill it said they replaced right tie rod due to wear. Personally I think they damaged it during the repair and just said it was bad to run it thru warranty. Over all I have been very happy with the kit and would recommend it.
Old 01-25-2009, 03:41 PM
deisele75's Avatar
deisele75
deisele75 is offline
I'm at 38,000 with no problems.
Old 01-25-2009, 04:25 PM
DesertStorm's Avatar
DesertStorm
DesertStorm is offline
3000, no problems
Old 01-25-2009, 04:39 PM
silver05fx4's Avatar
silver05fx4
silver05fx4 is offline
Im at 10,000 miles with 35' and 2.5 leveling kit with lots of off roading and high speed 4x4 driveing in snow and never a problem
Old 01-25-2009, 04:46 PM
jstnromero's Avatar
jstnromero
jstnromero is offline
at 31,000 miles on the leveling kit....31,982 on the truck....as you can see i did not wait to level the truck. I got the truck alligned as soon as I got the kit on the truck and have had no problems to date.
Old 01-25-2009, 07:14 PM
Muddedprairie's Avatar
Muddedprairie
Muddedprairie is offline
45K on mine with a 2.5 kit Happy as the day i installed it.
Mark
Old 01-26-2009, 11:14 AM
BrianFX4's Avatar
BrianFX4
BrianFX4 is offline
I'm at 90K with the truck and about 70K with the 2.5" leveling kit.
No problems here at all so far!
Old 01-26-2009, 01:19 PM
Carnivore's Avatar
Carnivore
Carnivore is offline
ok i have about 38,000 miles on my kit and i had one of the front tie rod ends replaced before and one replaced after, so i don't think the kit was responsible. I think they just went bad. Other than that, no problems at all.
Old 01-26-2009, 07:44 PM
Brian429's Avatar
Brian429
Brian429 is offline
I have somewhere around 55,000 on my 2" AS. Keep my tires rotated and my alignments done on a regular basis...no problems!
