390 starter issues
390 starter issues
the original starter on the truck got replaced with a new one from auto zone
i had problems with it after about 4 uses so i removed it had it bench tested checked for metal flakes on or around the area s of question but no resolve the starter tested good on all areas
so i reinstalled it and after 4 uses the same problem its as if its not making contact with the fly wheel no missing teeth on either and it has started before with this starter ive shimmed it back before all this thinkin its overtraveling not the case
at this point ive already called autozone qnd want to return this valuecrap starter for another reman
but is there any thing im missing or should look for?
thanks
thanks
Last edited by 400944; 01-24-2009 at 05:47 PM. Reason: its a 73 te block bolted to a c6 at
I was going to respond earlier and say that you should make sure the bellhousing is bolted to the block, but that would cause your starter to grind into the ring gear before anything.
So you are saying that the starter spins and does not engage the ring gear? I can think of a few reasons for this happening, and both you should NOT have to deal with on a new part under warranty.
Take that junk back!
I've seen this happen where a previous bad starter tore up the leading edge of the teeth on the flywheel making it next to impossible for the new bendix to engage. But that usually means several bad starters over a long period of time. Then it could be the bendix on the new starter is bad or the wrong one.
well i just went to auto zone and got the reman they appeared to be different same mtr but the starters appeared different one was polished and one was a duller aluminum
im going to go put this one on and hope this resolves my problem
and yes your symptoms are the same as mine light wear at the edge of the teeth
thanks
thanks
AtlM5
12-13-2015 07:57 PM
budhead1
1997-2006 Expedition & Navigator
01-27-2006 04:10 PM
