pcv question
Old Jan 24, 2009 | 07:37 AM
66flareside's Avatar
66flareside
pcv question
I have a decent amount of blow by coming out of each valve cover. The pcv is on the passenger side and I have a breather on the other. The problem is the breather has oil spilling out of it. So can I tee off the pcv hose and run two pcvs? Or can I run one pcv on the passenger side, and run the other side into the air cleaner?
Thanks,
Brad
Old Jan 24, 2009 | 12:49 PM
66flareside
anyone have any ideas?
Old Jan 24, 2009 | 01:01 PM
Bear 45/70's Avatar
Bear 45/70
The PCV system is designed to pull fresh air into the left valve cover (either directly or thru the air cleaner) thru the engine and pull all the fumes with it then thru the valve into the intake to be burned. You have one of three things wrong here.
1) The PCV valve is bad (plugged) and not letting air thru into the intake.
2)The vacuum hose is plugged or fitting into the intake is plugged or the gasket is wrong if the hose goes into the carb spacer.
3)Or your engine has so much blow by (AKA bad rings) that it is over powering your PCV system
Old Jan 24, 2009 | 01:03 PM
jowilker's Avatar
jowilker
I am sure one of the other heads can splain it better than me, but I'll give it a shot.
Sounds like the setup is correct, but if oil is coming out of the vent on the drivers side, it indicates to me that there is no hose connected to the pcv valve. There should be a hose connected to the pcv and to either a plate under the carb or on later vehicles into the breather.
You want vacuum to sweep the engine of those gasses, by pulling air into the drivers side, through the block and out of the passenger side into the engine to be burned. Rick at Carolina Classics in Durham NC has the hose, because I got one from him recently.
I see da bear was writtin at the same time as me.
John
Old Jan 24, 2009 | 01:20 PM
Bear 45/70's Avatar
Bear 45/70
I just thought of something. The head oil drain holes could be partially obstructed and causing to much oil to stay on top of the heads creating this problem too.
Old Jan 24, 2009 | 01:34 PM
66flareside
o.k, I checked it out and the pcv hose is going directly into the carb spacer and it has ALOT of vaccum. if I put my thumb over it I can feel it. and with the engine off the pcv valve will rattle when I shake it.
I had the valve covers off recently and and everything looked good. no noticable obstructions.
Old Jan 24, 2009 | 01:36 PM
66flareside
so I got a new breather with a grommet hole in the top. can I run an elbow off the breather, to the air cleaner. and continue to run a new pcv valve in the other side?
Old Jan 24, 2009 | 01:39 PM
Hypoid's Avatar
Hypoid
That is correct.
Old Jan 24, 2009 | 01:41 PM
66flareside
o.k i'll try that.....thanks everyone..
Old Jan 24, 2009 | 01:46 PM
Hypoid's Avatar
Hypoid
Keep us posted on the results.
Do you have a factory air cleaner housing? If you have a lot of blow-by, the oil will leak out there instead.
Old Jan 24, 2009 | 01:48 PM
66flareside
no,it's an aftermarket
Old Jan 24, 2009 | 10:33 PM
Hypoid's Avatar
Hypoid
I was wondering about that.
I can probably find a factory Thermal Air Cleaner for winter driving. I have run with and without, I'm keeping my TAC.
Let us know how the new plumbing works out.
Old Jan 25, 2009 | 10:21 AM
66flareside
It worked out well. I basically got the same breather I have pictured there, but it has one big hole in the top instead of holes around the bottom (like that one). So I used a plumbing elbow that happen to thread into the rubber grommet in the top of the breather, and then ran heater hose off the elbow around, and into the base of the air cleaner. The air cleaner base came setup with the parts for such an application. I drove it around last night for about an hour, at highway speeds (which with 4.56 gears is turning a high rpm) at the system seemed to work well. No oil anywhere. If you want to see the set up I can take a picture.
Old Jan 25, 2009 | 07:26 PM
Hypoid's Avatar
Hypoid
Ah like piktuuuures!
OhMyFawd
Nov 12, 2016 11:13 AM
mvvette97
Jan 10, 2015 11:18 PM
kc10fo
1978 - 1996 Big Bronco
Jan 10, 2014 07:36 PM
johaner78
Dec 22, 2011 01:13 PM
4rdnut
Dec 22, 2010 03:28 PM
