Schaeffer's series 7000 15W-40 oil analysis
Mostly use the truck to pull our 5th wheel camper & my daily driver for work. The analysis from July had about 5,000 miles towing and the most recent one in January has maybe 2,000 towing. I hit the drag strip & dyno once in a while - but not that often. Just more out of curiousity of where I stand as far as time & HP are concerned.
Sounds good Adam, you'll like the results (and smell!)
Mike, the 9000 has some great results on UOA also. The first time on Schaeffer's is often the "change over & flush period". Usually Schaeffer's reps tell folks to do an oil analysis at 5K or change the oil at this interval. Since Schaeffer's has an stout additive package it tends to clean the system out on the first run. It took me a couple of oil changes to get to this interval level. I started out at 5k, 7k, 8K, now up to 9K. I'm sure I could send in analysis at 9K and go from there since the oxidation & nitration levels are way low and the wear metal limits are not even close to the top end of the normal limit yet.
white Buffalo
90
10-27-2015 04:01 PM
robinsonpowerstroke
18
03-02-2013 09:55 PM
robinsonpowerstroke
09-29-2009 10:44 AM
