What would you guys recommend? I’ve been running the 9000 5w-40 for almost 10k miles and about to do a change. I have the stock oil pump and remember I live in Michigan so it is about to start getting cold. If you recommend the 7000, what viscosity, 15w-40 or the 5w-30? Thanks a lot for the suggestions.
Synthetic oil makes for easier starts in cold weather. I have ran both and my oil analysis ' are cleaner when I run 9000 vs. 7000.. however.. I have no problems running the 7000.. just depends on if I have 9000 in my shop.. if not I go to my tire shop and they carry 7000
I'm on my third run on the 9000 product, getting roughly 15+K between cahnges now. Need to send in my last sample for analysis, but I'm sticking with the 9000. If it works as well as I;ve seen down here in the hot south, I believe you should be golden with it up where you are. The 9000 is a little more expensive, but it is also a full synthetic as opposed to a synthetic blend.
I like the idea of 5w for the cold and the 40 for the hot days in the 9000. The only thing I don't like is the shearing of it that some guys are talking about. I think I am just going to stick with the 9000 because I go 10k per change.
