engine kills when shifting
Old 01-20-2009, 10:24 PM
tbirdrief's Avatar
tbirdrief
tbirdrief is offline
Hello,
When I shift the engine kills. When I let out the clutch it starts right up.
I thought that my fuel was bad changed filter, but still happens.
Any ideas.
Thank you,
'89 F350 4X4 7.3
Old 01-20-2009, 11:43 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
At any speed?
Old 01-21-2009, 07:57 AM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
Does it do it when the clutch is pushed in anytime........ stops, cornering etc. If so then there is a TSB for that problem. Relates to dirt/crud/ slime in the IP.
If you would like the TSB....
click on my name and PM me your email addy.... Use subject: TSB IP
Old 01-21-2009, 04:55 PM
tbirdrief's Avatar
tbirdrief
[QUOTE=PLC7.3;7036991]Does it do it when the clutch is pushed in anytime........ stops, cornering etc. If so then there is a TSB for that problem. Relates to dirt/crud/ slime in the IP.
Hi,
I stalls at mostly lower speeds (stop sign/light) and when it is not quit up to peek temp. When it is up to temp and I have been workin her I haven't noticed it.
Thanks
Old 01-21-2009, 06:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
A good strong dose of Diesel Kleen may fix your stalling issue.
Old 01-21-2009, 10:10 PM
tbirdrief's Avatar
tbirdrief
Thanks I'll try that first.
Old 01-21-2009, 10:33 PM
David85's Avatar
David85
David85 is offline
+1 on that
