85 Ranger
85 Ranger
Ok Im pretty darn familier with the larger f series trucks but the ranger is kinda unknowen to me and Id like some idea of what Im getting into.
A guy at work has a 85 4x4 ranger he just bought and wants me to work on it.
What V-6 could that be?
Is that and autolite 2100 carb on it?
What trany is it?.........Its a 5 spd manual.
Am I nuts or does that have full ford EEC-III? Wow!
The truck runs ok so I just kinda want some idea of whats in it.
You're right Wendell, the truck may have either a TK5 (Toyo Kogyo 5spd) or Mitsubishi FM145, most likely it will have the Mitsubishi. The motor will be a 2.8l V6, which was the only 6 banger in '85. EEC III, that sounds about right. You will find a spout connector, EGR system, and even a basic O2 sensor, all built around the 2150 carb. Never made any sense to me since the 2bbl shaped throttle body injection system was already on the 5.0l and 3.8l by this time, but that's just the way ford did things. I loved 2.8l engines, the timing gears and solid lifters made them noisy and earned them the nickname, "the sewing machine" but they were durable and efficient when they ran right. I had an '85 Bronco II a couple years ago that got 21-22 MPG, but it cost me plenty to get it back into good enough running condition to get that mileage when I bought it! Great truck when you get it whipped into shape, but beware that the engine management systems can be a real headache.
Eh, Mazda/ Mitsubishi - I never was much on japanese names!. Mitsubishi 5spd it is!, The best mod to this engine is to scrap out the TFI EECIII system and go with the old dura spark ignition and distributor (really wakes these little motors up) then find a old 2100 or 2150 non feedback carb. The difference in power and driveability is incredible. Some folks put a 350cfm holley 2bbl on them, but it really doesnt gain much over a well tuned motorcraft. A 4bbl manifold is avail. from Offenhauser, and a 390cfm holley 4bbl works well. To use this set up a cam and porting would help as a stock 2.8 cant quite use all that cfm. Headers are available thru Edlebrock, but early Aerostars with the 2.8 used headers from the factory for clearance issues and with a little modding you can use them on the Ranger, 4x4 or 4x2. If you go with the duraspark conv. you can get rid of ALL the emission garbage that hampers these great little engines.
goodolefletch
1983 - 2012 Ranger & B-Series
12-02-2003 09:47 PM
TonkaF150
09-17-2003 03:19 AM
